Question about Video Game Consoles & Games
When you switch on the PS3 it bleeps and the red light on the front flashes, it will not except a disk, and the green light which normally comes on does not light up. Do you have any ideas please.
  • markmarlinma Sep 06, 2010
    I have a PS3 when you switch it on it bleeps then the red light on the front just flashes, the unit does not power up??
    I have a PS3 when you switch it on it bleeps then the red light on the front flashes but the unit will not power up any ideas??
  • 666 Answers
This is the red light of death it means the ps itself has internal component damage and either needs to be repaired or returned
hope this helps
Robb
Posted on Sep 06, 2010
    President:
  • 1,139 Answers
This is because of a general hardware failure, usually caused by overheating. You may have heard of the term "Yellow light of death" but this is different from that. It basically means that irrepairable damage has happened to the console due to overheating and cannot be fixed. If the PS3 is under warranty you could give Sony a call but if it is out of warranty you will have to pay for a repair or sell the PS3 as faulty. You could get around £60 for it on ebay sold as faulty. For Sony to repair is out of warranty will usually cost around £130-£150. I know it is not the news you want to hear but I have seen many of these console that have suffered this fate and there is nothing you can do to fix it.
Hope this helps and thank you for using FixYa
  • 19,396 Answers
Hi.
The PS3 is in hardware fault mode. The most common occurrences are faulty hard drive or faulty optical drive.
If possible take out any disk from the inside.
Turn the console off by holding the button at the frontuntil the console goes on standy, then turn it off using the switch at the back.
Disconnect all cables and connected devices, including power cable.
Wait ten minutes and connect power cable only.
If PS is still in fault mode, test the hard disk:
Disconnect power again.
Remove the internal hard drive following the procedure on manual.
Reconnect all wires and turn the ps3 back on with no hard drive.While turning on hold down the On button in front until hearing two beeps.
If the PS starts, then the problem was the hard drive. This can be replaced with a laptop 2.5 inch HDD. If the problem is still in fault mode, then a different part is faulty (often the main board).
If PS3 is still in fault mode after doing the procedure above, then the best option is calling Sony. The choice alternative is taking the console apart and testing it, but you will need some technical training and experience or you risk to inflict more damage to the console.
Here contacts:
Sony eSupport Global
US PS3 - Contact Us
When you turn on the ps3 the red light stay flashing
hello it sound like ylod problem thses means it's overheated you could try a reset.turn ps3 on then press and hold the standby on the front of the ps3 you will 1 bleep then 2 short bleeps after the short bleeps release the button it might reset hope it helps
regards
shaun
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
My sons ps3 will not turn on when you turn it on the light goes green then flashes red the game will not eject can u help?
hello, have you tried resetting it turn the ps3 on then press and hold the standby button on the front of the ps3 you will hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset . if this don't work then you may have ylod problem these means it's overheated if it's still gaurantee the contact sony hope it helps
regards
shaun
PLaystaion is broken it flashes red then i turn it on and it goes red then it goes blue then yellow and then beeps and goes back to flashing red and it wont turn on
hello have you tried a reset ,press and hold the standby button on the front of the ps3 you will hear 1 bleep the 2 short bleeps after the short bleeps release the button hope it works
regards
shaun
Oct 24, 2010 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on the green light comes on turns yellow then turns off which it then has a flashing red light how do i fix this problem?
hello try a reset press and hold the standby button on the front of the ps3, you hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset good luck
regards
shaun
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
When I turn on the PS3 it makes loud driver noise and the blue /green lights come on but after 30 seconds it beeps 3 times and flashes red. There is no orange or yellow flash. Someone suggested taking out...
hello have you tried to reset it.while in standby mode press and hold the power button you hear 1 bleep then 2 short bleeps release the power button this should reset the ps3 make sure you've got it connected to the tv screen hope this helps
regards
shaun
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
When I turn my PS3 on it bleeps then doesn't work
This is the yellow light of death. It happens when the system overheats causing the solder to melt on the board. It needs to be reflowed professionally. Contact Sony if it is still under warranty. If not, check out www.wiredextreme.com. We are a game console repair company that is BBB accredited. All of our repairs come with a 90 day warranty. Feel free to call 1-888-389-3038 or e-mail support@wiredextreme.com if you have any questions.
May 04, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Flashing red light
Go to you www.youtube.com and you may be able to find helpful videos on this. But if you bought it new it is under warranty and they will fix it. You just pay for shipping.
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
