Question about Microsoft Xbox 360 Console
It says system error when you turn it on and there is a red light on the green circle power button.
  • Tom Kilroy
    Tom Kilroy May 11, 2010
    In the lit circle there are 4 lengths, or individual lights. Can you please clarify which lights are red, and if they are flashing or not?
    Consider the upper left light to be #1, and so on clockwise.
    This is considered the "red ring of death", and there are a number of things that could be wrong. With your clarification I should be able to help you.
  • Adam Austin May 11, 2010
    How many and which red lights appear on power button? It is separated into sections and the pattern of red lights is important to determine what is wrong.
  • 41 Answers
Its states in the manual, 4 lights mean AV cable error.
also you can try removing the hard drive and try running it then, let me know how it goes.
Posted on May 13, 2008
ERROR CODE 5800
Follow these procedure
1. Turn off the canon printer.
2. Hold button Resume/Cancel (red triangle in the circle), click on POWER - an indicator light green.
3. Release the button Resume / Cancel keeping POWER.
4. Click Resume/Cancel 2 times, keeping POWER, and then release all the buttons.
5. When the indicator recorded GREEN - click Resume / Cancel 4 times!
6. Turn off the printer POWER button.
7. FINISH
I think You will be relif from your printer problem.
Thank you very much.
Jun 05, 2011 | Canon Pixma MP500 All-In-One InkJet...
Hi, i can no longer use my canon ip1980, the error message " ink absorber full, contact your service provider" how can i fixed my printer? thanks
7. FINISH
i hope this helpful
thank you for using fixya
Mar 16, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
How do I reset an 5800 error code on my Canon mp500? Waste ink full code.
7. FINISH
i hope this helpful
Feb 16, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Canon Pixma MP450 All-In-One InkJet...
ERROR 5100 CANON PIXMA MP 450 It does not work when off from KOPJUTER
Hello
Dec 17, 2010 | Canon Pixma MP450 All-In-One InkJet...
I have a error number 5b00 problem
Follow the procedure to reset the waste ink tank counter:
1. Turn off the printer ( “Power” button).
2. Hold the button “Resume” (red circle in the triangle), turn on the printer (click “Power”) – an indicator light green.
3. Hold the “Power” button, release the button “Resume”.
4. Not releasing the “Power” button, double click “Resume” and release both buttons.
5. Four times click “Resume”
6. Once you click “Power”, to confirm the selected action (reset counter absorber). Click “Power” button again to turn off.
Aug 09, 2010 | Canon Office Equipment & Supplies
The on button keeps flashing and the red light stays on
Try resetting your Canon PIXMA. Here's how:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Have a good evening!
Jan 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My xbox360 has a red circle instead of a green circle theirfore will not work what can this be
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death"), represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off.
This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console.
Distinct from the General Hardware Failure is a similar-looking error warning where four red lights appear, in which case the console does not detect an AV cable is plugged in. The four lights can sometimes also be seen when power surges or very brief power outages occur while the console is running, in which the console needs to be unplugged and plugged back in again to reset the error. Two red lights appear when the system is overheated.
Oct 06, 2009 | Microsoft Xbox 360 Console
ERROR 5800
1. Turn off printer.2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color.
Apr 24, 2008 | Canon Pixma MP450 All-In-One InkJet...
Microsoft Xbox 360 Console Logo
14 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
