Question about Tag Heuer Watches
I have recently bought a Tag Carrera Calibre 16 and now the date will not change when i turn the knob. It was working up until this week. Seems like its stuck. Help
    President:
  • 2,501 Answers
Take it back to the nearset dealer or service center. It will still be under warranty and they should fix any problems free of charge.
Do not attempt any repairs yourself, as it will invalidate the warranty.
Posted on Sep 06, 2010
How do Iset time tag watch carrera calibre S
Very good video of this on youtube.
http://www.youtube.com/watch?v=EQJUl64EMIE.
Good luck, as the guy on the video says it is complicated!
Oct 18, 2014 | Tag Heuer Carrera Watches
How to seconds hand
Hi Johar,
I will advise you to contact your manufacturer to avoid warranty void due to damage during the process of setting it. Try the link below.
Contact Us TAG Heuer
May 09, 2014 | Tag Heuer Grand Carrera Automatic Calibre...
Instruction manual
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps .
Sep 01, 2013 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
My watch stops very often its tag heuer grand carrera calibre 17 rs2 automatic one what do i need to do for continuous running of my watch
It rather depends what you mean by "very often".
An automatic watch will run for 2-3 days before stoping if it is not used.
These watches thrive on being used and are best used every day.
It could be that your watch needs cleaning (I had one that was like that when I bought it and I had it cleaned and it ran for years after that).
Jan 21, 2011 | Tag Heuer Grand Carrera 17 RS CAV511B...
Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Mar 25, 2010 | Tag Heuer Automatic Chronograph Series...
Tag Carrera CV2014 Date Keeping problem.
Lets get down to the facts.
The watch may have been serviced and may have been the beginning of this problem.
BUT is it really a problem?
Changing a 1230 or 0330 still means its on the correct date in the morning.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Tag Heuer Carrera Automatic Chrongraph...
TAG Heuer Carrera Calibre 16
Hi
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Cheers
Dave
Jun 21, 2009 | Tag Heuer Link Automatic Chronometer...
Quickly change date on my Tag Carrera
When yoy pull out the crown you will notice there are two clicks. You have to pull out crown to the first click only and then adjust a date by turning the crown.
Rate me, please.
Mar 13, 2009 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Watches Logo
265 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
