Question about Apex Digital AT3208S 32" TV
Remote codes I need codes for this remote apex ck5g-c1
  • 3 more comments
  • Anonymous Jul 14, 2008
    I need codes for this, also. The Apex support website shows downloads, but the links don't work.
  • Anonymous Jul 31, 2008
    need code to reprogran universal control.
  • Anonymous Aug 22, 2008
    asdf
  • christine119 Dec 11, 2008
    i need code to rca remote to my 32in apex
  • Anonymous Apr 30, 2009
    My ck50-c1 Apex remote will not work at all. Unsure if I need to program with a code. Been a while since I had it, and can't remember.
Can someone help me find the codes for apex ck5d-c1 thank you
Posted on Dec 02, 2008
Here is the PDF Owner's Manual:
http://www.apexdigitalinc.com/manual/AT3208S.pdf
Posted on Nov 14, 2008
I need the code for apex ck5d-c1
Posted on Aug 09, 2009
I need the codes for the remote apex AT3208S
Posted on Nov 09, 2008
2 Suggested Answers
SOURCE: Finding a code
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
Posted on Oct 25, 2007
Will apex ck5g-c1 remote control program to rca dolby digital analog pass through analog converter stb7766c
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 20, 2016 | RCA Televison & Video
Need code for apex ck5d-c1 remote to program. To a gem tv
Jan 17, 2016 | Televison & Video
How do i remove key symbol onpicture of TV
The TV is locked. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Oct 02, 2014 | Televison & Video
How do I unlock an apex at2704 with an At&T uverse remote?
These are the steps to unlock Apex TVsApex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Sep 02, 2012 | Apex Digital Televison & Video
I need the code to apex uk2a-c1.
go to www.. fitness.manualsonline.com or www. remotecodelist.com
God bless you
May 16, 2012 | RCA Televison & Video
Need remote code for old zenith vcr model IQVB423
I couldn't find any codes for Zenith in my code book, so I am wondering if it is made by another VCR maker and users that code?
Oct 06, 2009 | Zenith IQVB423 VHS VCR
Need samsung remote codes for apex tv
Go to www.apex.com and query for the manual to the controller
Jun 17, 2009 | Televison & Video
Finding a code
Oct 22, 2007 | Apex Digital PF3220 32" TV
Remote contol volumn won't work
The buttons themselves may not be making contact. I've had to take some remotes apart and clean the carbonized rubber pads that touch the contacts on the circuit board. Most remotes can be pryed apart very carefully and cleaned. If this doesn't help it is possible that the incorrect code is in the remote. Also part of the chip that generates the digital pulses could be bad. You might need to get another remote. Stargazer
Aug 11, 2007 | Apex Digital PF3220 32" TV
Apex Digital AT3208S 32" TV Logo
1,993 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
