Question about Insignia IS-LCDTV32 32 in. Television
The tv blew while watching it. - Insignia IS-LCDTV32 32 in. Television
  • Anonymous May 13, 2008
    about every 3 or 4 days my tv just shuts off...its a 42 in. phillips plamsa 3 months old
  • 56 Answers
If its under warranty take it back is the easiest way possible to solve the problem if not check the fuses inside the tv if you know what your doing I dont want you to fry yourself if the fuse(s) are ok its probably the main transformer.
Posted on May 22, 2008
Was watching when it made a sound like a fuse blew out now TV will not show picture
Sounds like your lamp blew out. Check to see if you have any led lights on the tv that show "lamp". Lamps are easy to change out and you can find them on eBay.
Oct 16, 2015 | Televison & Video
I was watching TV and it just cut off. There is no power light on and the outlets are working and the cord is firmly in.
good day sir/maam, chances are yout tv just blew a fuse, when a fuse blew up, there are several reasons.
  • It protects your tv from further damage.
  • a part of your tv got bad, causing it to blew.
You have a choice of calling your service center/dealer or do it your own.
If you decide to do it yourself, these are the steps you may need to do.
  1. Open the TV's back cover, to access the circuit. locate the blowned fuse.
  2. you may need to pull out the entire board, to test it.
  3. test the switching regulator IC/transistor for shorts, (you may need a multitester).
  4. check for open low value resistors, less than 100 ohms.
  5. You really need to find the cause of the blew up fuse. part by part checking is necessary,
  6. replace the bad parts and test again.
  7. if everthing else fails, you really need to call your service.
note: if you simply replace the fuse without tracing the blew up shorted bad part, chances are the fuse may blew again.
Oct 02, 2009 | Vizio L32 32 in. LCD HDTV
Power went of HDTV sound works but not picture
blew the opower supply and if you are lucky,juse a fuse or varistor
Apr 09, 2009 | Sanyo DS31520 31" TV
TV only 2 months old ceases to work
Hi
I think it is the EHT for some reason it blew off for you. You got a miniature picture after you turned it on again because it was partially damaged and then it blew off completely. It can be fixed from a competent person.
Regards
Jan 07, 2009 | RCA TruFlat 27F520T 27" TV
Will not turn on.
If the TV is blowing the fuse in your house, It looks like a component in the power supply is shorted.
To fix the TV, you will need to buy a new power supply module or get the one inside the TV fixed.
Good Luck.
Apr 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
27F522T RCA
REPLACE IT! IF IT BLOWS AGAIN THEM IT TIME TO SEND IT TO A SHOP
Dec 06, 2007 | Televison & Video
Proscan tv ps27123
a capacitor blew up, or the flyback exploded?, happened to a RCA 27" tv i used to have!
Nov 22, 2007 | Proscan PS27123 TV
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Tv wont turn on
check if the main fuse blew up. good luck!
Feb 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Insignia IS-LCDTV32 32 in. Television Logo
53 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
