Question about FarPoint Spread for Windows Forms 6 (swn01-6upgrade)
File License.DAT not found - FarPoint Spread for Windows Forms 6 (swn01-6upgrade)
How to change a Dat file so I can open it on my Samsung tablet
DAT is a file extension that's mostly found on video CD. It is usually used to store MPEG-1 encoded video on VCD. This kind of video file is file format that are not playable in the default Android video player.
But don't worry, there are ways to make it playable. In this article, I'll show you how to play DATvideo file on your Android device.
To be able to play DAT video file in your Android device, you should need the help of a third-partyvideo player app. In this case, I suggest you to use MX player.
MX player is one of the most popular video players that can play almost every video format. It also play all resolutions that supported by your device.
If you don't have one, you can download it for free at Google play store.
Once installed, open the DAT video file with your file manager app and the video should be loaded and played by the MX player. However, you're unable to load DAT video file on 'My files' or 'Gallery' app, as well as 'MX player'. To be able to open DAT video file directly from your Gallery app or MX player, you should rename the file extension from .DAT to .MPG. For example, filename.dat change to filename.mpg. Once you're done, the video will appear on your MX player list and you can now play the video file on your Android device.
Oct 23, 2014 | Samsung Cell Phones
Cannot open pdf file in email
This is a known issue with users sending PDF's using Microsoft Outlook. The link below gives instructions on how to change on their end.
Link:
PDF file changed to DAT file on receiving end when using Outlook in...
I also found a solution that might work on your end...This is from a blog post on the Apple forums.
This is a common problem.
I have found a converion web-site www.winmaildat.com, where you upload the problem file, and it is automatically 'deciphered', and the contents can be downloaded in their individual files.
Dec 05, 2012 | Apple MacBook Air
Windows vista - ZTE AC2726 wireless data modem HSD USB Card unins000.dat file
http://www.4shared.com/file/E2DmPGFU/unins000.html?refurl=d1url
same here . use this file and put to the missing folder. then try to install or uninstall
Apr 22, 2012 | Computers & Internet
Tanor dx licensefile.dat file
sir quintum license.dat file
sn=A0423028BA plz send the mail.
mail id-avatar.netspace@gmail.com
Feb 25, 2012 | Quintum Tenor DX2060 (501-0122-00)...
Deleting files
Im assuming you want to delete browsing history. You can go to Internet options in the control panel and delete browsing history there but to completely remove history files you need to delete the index.dat file.
This file, if you're using windows XP can be found in different places:
C:\Documents and Settings\<username>\Cookies\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\MSHistXXXXXXXXXXX\index.dat
C:\Documents and Settings\<username>\Local Settings\Temporary Internet Files\Content.IE5\index.dat
C:\Documents and Settings\<username>\UserData\index.dat
If you are using a different operating system, just search for index.dat and make note of the locations.
Once you've noted where the locations are you need to restart the computer and log in using safe mode. In safe mode pull up a cmd screen by going to start>run> then type cmd and hit enter.
In the cmd screen change directory by using the command cd C:\Documents and Settings\<username>\UserData for example and then del index.dat (to delete the index.dat file).
Restart and you're good to go.
Apr 06, 2010 | HP Pavilion dv6000z Notebook
Nokia 6600 License Key
u can download cracked ultra mp3 at www.funmaza.com after install put 0000 in register window u can enjoy the full version
Aug 28, 2008 | Nokia 6600
.dat format songs
They are not songs - they are critical system files -do NOT delete them
Feb 01, 2008 | SanDisk Sansa c240 MP3 Player
Regd the .dat file
You cannot open a data file this is only read by a programme or the operating system, but what may have happened is that you have been sent a file for which you do not have a programme for it to open with and windows has use the.dat as default. If you know who sent it and what file it is suppost to be, ask them what file it is eg a picture or video file and use one of your own programmes to open it using the right click and 'open with' method.
Apr 12, 2007 | Western Digital Caviar WD400BB 40 GB Hard...
Computers & Internet Logo
1,202 people viewed this question
Top FarPoint Computers & Internet Experts
David Payne
David Payne
Are you a FarPoint Computer and Internet Expert? Answer questions, earn points and help others
