Question about ASUS R300 Portable Satellite Navigation Bluetooth Car GPS Receiver
I have a R300 Asus Portable navigation On-the-Go, when I click navigation, it says operation failed to insert SD card or unplug usb or if it goes through it says fatal error or no language files were found. What do I do
IB4G2008
  • 3587 Answers
SOURCE: navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Posted on Mar 09, 2008
IB4G2008
  • 3587 Answers
SOURCE: Navigation fatal error Error 1706
yes..I saw that..need teh model number of the actual gps you are using, please..
  • 6 Answers
SOURCE: Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Posted on Feb 16, 2010
  • 11800 Answers
SOURCE: Asus P5RD-2-UM acpi bios revision
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Posted on Dec 20, 2010
maxcarson
  • 7627 Answers
SOURCE: How do I download photos from a SD card to as Asus E Book
You should get a popup. You didn't specify the Model of Asus, try here for a User Manual: http://www.asus.com/Eee_Family/Eee_Reader_DR900/
Posted on Mar 28, 2013
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
Nov 26, 2013 | PNY 1GB microSD Memory Card
Pny sdhc card protected
or you might
Click on "Properties" and then navigate to the "Security" tab. Scroll down to the heading labeled as "Permissions."
Nov 23, 2013 | PNY 4GB Secure Digital High Capacity...
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Jan 10, 2013 | SanDisk 4GB microSDHC Memory Card
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
How do you move your memory from phone to sd card?
  • 1 Insert your new SD card into your cell phone. For most devices, you will have to slide the card into a slot on the side of the phone or remove the battery and insert the card into an encasement. Replace the battery (in the latter case) and boot up the phone.
  • 2 Connect the cell phone to a computer using a USB cord (make sure the cord is compatible with your particular mobile device). This cord sometimes comes in the package when you buy a new phone.
  • 3
    Wait for the computer to recognize your new hardware (the phone). A dialog box will appear asking you for instructions regarding the new portable device. Click the option to open your device's file folder. You should see a folder for the media card and your device memory.
  • 4 Go to the device folder first and select all of the files and folders that you want to transfer to the SD card. Press "Ctrl" and "X" to cut the files from that folder.
  • 5 Navigate back to the media card folder. Press "Ctrl" and "V" to paste the files onto the SD card.
  • Mar 25, 2012 | Cell Phones
    I am trying to transfer music off my archos to a sd card for my phone how do i do that?
    you will need to insert the sd card if your model archos has the support dont think they have a usb ability
    click start all programs open windows explorer click on my computer you should see your sd card it might be listed as a massstorage device navigate to the audio files the select the audio files right click copy and then go back to your sd card and right click select paste or select all?media files?click and hold the cursor and drag and drop them to sd card and drop them in or select the audio files you want right click and select send to your sd card hope this helps
    Jul 17, 2011 | Computers & Internet
    How do i download music frm my laptop to my sd
    Insert the SD-card into a SD-slot in your computer, if your computer has such a slot. Then, Windows will assign a "drive-letter" (not 'A:' or 'C:' or 'D:', but you get the idea) to the storage-device.
    Then, copy files from your C: drive-letter to the "new" drive-letter.
    Or, if your SD-card fits into your portable music-player, and the music-player can connect to your computer with a special USB-cable, then insert the SD-card into the music-player, and connect the USB-cable, and turn the music-player on. Then, copy the files.
    Apr 02, 2010 | SanDisk 2GB microSD Memory Card
    How do I delete cameras set on maps
    go to the control panel and delete the files
    Apr 24, 2009 | ASUS R300 Portable Satellite Navigation...
    Memory card issue with Epson r300
    Hi , reinstall the printer driver with sd inserted.
    Jan 25, 2008 | Epson Stylus Photo R300 InkJet Printer
    ASUS R300 Portable Satellite Navigation Bluetooth Car GPS Receiver Logo
    41 people viewed this question
    Top ASUS GPS Experts
    Jerry Umali
    Gil Shultz
    Are you an ASUS GPS Expert? Answer questions, earn points and help others
