Question about Nikon MH23 Quick Charger (25349) for EnEL5 Liion Battery
My MH-23 won't charge my EN-EL9a battery. Upon testing with voltage tester, the electricity doesn't flow through the charger.
2 Suggested Answers
SOURCE: when i plugged it in for the first time to
I faced the same problem too. But I realised that after plugging in the adapter and connecting it to the camera, you would need to press the power button but not turn it on.
Posted on Jul 02, 2010
NI-MH D 14.4V 8000mAh Charger Hack. I need an alternative charger like charging on a car battery?
NI-MH batteries a re very different than car batteries and even tho voltage may be similar, you risk destroying your battery, camera or worse, an explosion. Your batter may only need a limited amount of amperage to charge (likely not much more than 1500ma or 1.5 amp) a car battery charger may put out twice or even ten times that much - hence the explosion risk! Also these kind of chargers detect when your battery is full and will quit charging or switch to a maintenance mode. I'm afraid you're pretty much stuck with using the charger meant for it.
May 08, 2016 | Cameras
Alternative battery charging
you cannot use any charger that is not used to charge ni-mh batteries car batteries charge at a rate of 5 amps minimum and if you do it will cause serious damage to the charger and batteries
if you want ideas , talk to a battery shop but unless it is designed to charge 14.4 volt ni-mh batteries-- forget it
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
What is a load tester for a batterie
A load tester is typically a resistance pack with an amp gauge to see how the battery deals with current draw. most automotive parts stores have one to bench test car/motorcycle batteries, which they do at no charge (pardon the pun).
Batteries can have a "surface charge"(voltage) which will supply low current at the specified voltage from a battery with bad cells, but when a real operating load, such as for an electric motor, the charge drops to zip..
If the charger is putting out voltage to the battery while it's plugged in then it would definitely be a battery issue, generally the charging system for electric wheel-chairs has regulatory circuits to prevent over charging so having one plugged in when not in use typically doesn't cause issues.
Sep 14, 2014 | Solar 125 Amp Analog Battery Load Tester
Won't charge
The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
Sep 19, 2012 | Nikon Coolpix 4100 Digital Camera
How to charge a nikon 40dx
Assuming you mean a Nikon D40x, the answer is: you don't.
Remove the EN-EL9 battery pack from the camera and insert it into the MH-23 charger or equivalent and plug the charger into a wall outlet.
If you need a charger, you may order one here. Alternatively you may order a third-party charger here.
Apr 04, 2012 | Cameras
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
Does this charge a battery for the D3100 SLR Nikon?
No. The MH-23 is for charging the EN-EL9a battery. The D3100 uses an EN-EL14 battery, which used the MH-24 charger.
Feb 03, 2011 | Nikon MH23 Quick Charger (25349) for EnEL5...
I have a travelmate 4060 laptop and I just replaced the battery through best buy with a generic one that was compatible. It is always saying 23% full. How do I charge this battery?thank you
1)Reason:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
2)Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
May 20, 2010 | Acer Aspire One PC Notebook
Nikon MH23 Quick Charger (25349) for EnEL5 Liion Battery Logo
335 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
