Question about Symbol PPT 8800 Wireless Barcode Scanner
It's stuck on the align screen - Symbol PPT 8800 Wireless Barcode Scanner
Align screen in imate PDAL.. I try many time to skip screen alignment but it did not work and i use MSP_RemoteAlignment but it not work
my imate pdal is stuck on the align screen...
as many times times as i tap on the target to align screen on all the four corner, it just comes back to the centre..... the whloe process repeats but just remains there....
any solution.....
Jun 09, 2009 | i-mate PDAL Pocket PC
Palm treo smartphone upon reboot gets stuck on "align screen"
yes u cant exit the screen until u do the align test for the touch screen its a easy fix on the back of the phone on the left side top there is a hidden pen that comes out of the phone and when u get the pen out use the point of the pen to touch the center of the circle on the align screen test it will ask u to do this in every corner of the screen after that the phone should get out of the align screen test and be able to work good luck
May 29, 2009 | Palm Treo 755p Smartphone
Screen alignment
press and hold the lock button on the lefthand side and tap the align screen.
if problem is solved pls post me thanks
Feb 03, 2009 | i-mate PDAL Pocket PC
Screen frozen
do the same at least 3 times it will be done
Sep 04, 2008 | i-mate PDAL Pocket PC
Align screen
i have the same problem wat to do i am stuck wit align..
Aug 13, 2008 | i-mate PDAL Pocket PC
I-mate jam mobile align screen message appearing & stuck on that screen only. Plz suggest me sonlution.
me also, i-mate jama mobile, align message appearing and stuck on the scereen only.., wat will be the solution for this?//
Jun 12, 2008 | i-mate JAM Pocket PC
Stuck on "align screen"
your touch screen gone just change your touch screen it goes back to normal
Mar 20, 2008 | HP iPAQ H6300 Pocket PC
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
Stuck on alignment screen. Tap all 5 places goes back to middle of screen
Yeap!
Check behind the battery if the S/N of your device starts with "HT627", If it does it needs to go to an HTC service center cause they have to apply some service advisories and correct the problem in warranty.
If it's not this serial then you need to change the LCD.
Jan 08, 2008 | HTC TyTN Smartphone
Symbol PPT 8800 Wireless Barcode Scanner Logo
82 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
