Question about Audiovox Cameras
Lens error: 21 - Audiovox Cameras
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 06, 2010
Camera is showimg lens error . l 21 nikon camera .
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 27, 2010 | Cameras
Im getting a lens error message on my h3dii ....message reads ... lens error id 21:1
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 22, 2010 | Hasselblad H3DII-31 Digital Camera
Lens error 21
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 15, 2009 | Sanyo DSC-MZ3 / VPC-MZ3 Digital Camera
When turning on camera a message of a lens error comes on, lens error 21?
call sony support see if still under warranty if not (register product then tell them problem)try cleaning all lens with rubbing alcohol and soft white t-shirt sensor lens maybe dirty!!!!
Jun 27, 2009 | Sanyo VPC-E760 Digital Camera
Lens error:21/16 on my sanyo vpc-e870
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 11, 2009 | Sanyo VPC-E760 Digital Camera
Sanyo vpc-E870
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 24, 2009 | Cameras
Lens error
Oct 12, 2008 | Sanyo VPC-S7 Digital Camera
I HAVE A PRAKTICA LUXMEDIA 7303 AND AN ERROR MESSAGE KEEPS COMING UP SAYING LENS ERROR 21
HAVE A PRAKTICA LUXMEDIA 7303 AND AN ERROR MESSAGE KEEPS COMING UP SAYING LENS ERROR 12 and 27
Aug 24, 2008 | GE A730 Digital Camera
My sanyo camera is not working
Well maybe I can solve this..... My lens would not retract and showed two error messages. Tried a number of tricks that have been recommended on this site to no avail. Ultimately what worked for me was pushing quite hard on the barrel of the lens trying to force it back in ( yeah i know, sounds extreme but did'n't think it could make the situation any worse ). The lens remained in the locked out position not moving in spite of the fact that I pushed it fairly hard. When I turned it on the lens retracted and it appears to be fully recovered from whatever was ailing it. Hope this works for you.
Jun 09, 2008 | Sanyo VPC-E760 Digital Camera
Sanyo vpc-e760 digital camera
i have the same problem ..
it was error 16 AND 21 .
im not entirely sure about the error 27 or any other
numbers ;
but i do know for a fact its because there
is something like dirt ; hairspray ; make up etc.
in the lens .
idk how to take the camera apart ..
but your best luck is to kind of jar your camera with your
palm or a book or something .
mine fell on the floor at first and was fixed ,
but today i dropped it in a little bit of sand and hasnt gone
back down yet .
im hoping i can fix it :/
let me know if any of you have any luck .
Mar 02, 2008 | Cameras
Cameras Logo
27 people viewed this question
Top Audiovox Cameras Experts
micky dee
venugopal durairajan
Are you an Audiovox Camera Expert? Answer questions, earn points and help others
