Question about Casio ClassPad 300 Calculator
How do i enter degrees minutes seconds on classpad 330?
  • Casio Master
  • 7,993 Answers
This is valid for the ClassPad 300Plus (OS version 2.2) but it should work for the ClassPad 330 OS version 3.x
In the MAIN menu screen press the Action menu, then Transformation sub menu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
Posted on Sep 06, 2010
3 Suggested Answers
  • 7993 Answers
SOURCE: how do I enter degrees
Posted on May 13, 2011
  • 7993 Answers
SOURCE: how do i enter a
Posted on Jan 31, 2011
Phasor addition on classpad 330
Open up keyboard, go to 'cat' tab and scroll down to get ' <( ' symbol.
Input the magnitude followed by angle separated by a comma (E.g. <(15,10) ). The first element in the bracket is the magnitude of the phasor while the second element is the angle.
To do phasor addition simply add more of the '<(' symbol. (E.g. <(15,10) + <(12,5) is the addition of phasor_1 with magnitude 15 and angle 10 and phasor_2 with magnitude 12 and angle 5 ).
Note: the symbol ' <( ' appears at the very bottom of the list and the '<' symbol is actually more flat in appearance like how a normal phasor is usually represented.
Apr 09, 2014 | Casio ClassPad 330 Graphing Calculator
Instalador de class pad 330 para 64 bits
You do not need any driver for the ClassPad 330. You connect it through the USB port. If it came with the ClassPad manager 32 bits application, just install it. Windows 64 bits system have a 32 bits subsystem to run 32 bit applications.
Google translate (without accents)
Usted no necesita ningun controlador driver para la ClassPad 330. Se conecta a traves del puerto USB. Si viene con el gestor de aplicaciones de 32 bits ClassPad, solo lo instale. Sistema Windows de 64 bits tienen un subsistema de 32 bits para ejecutar aplicaciones de 32 bits.
Mar 03, 2014 | Casio ClassPad 300 Calculator
Classpad 330
Here is a screen capture that may help you. Variable must be x. Be careful what type of brackets you use to enclose the arguments. use the ones that are on the same line as Pi, theta, i.
Sep 19, 2013 | Office Equipment & Supplies
How do I enter degrees minutes seconds on casio classpad 330
May 12, 2011 | Casio ClassPad 300 Calculator
Can you update a classpad 300 to a 330 operating system
It depends. If the ClassPad has OS 1.x you can upgrade it to 2.x freely. However you need to buy (separately) the ClassPad manager 3.x to be able to upgrade the OS to version 3.x. After that further upgrades appear to be free.
Feb 05, 2011 | Casio ClassPad 300 Calculator
How do i enter a degrees/minutes/seconds value on a casio classpad 330
Jan 30, 2011 | Casio ClassPad 300 Calculator
I dont know how to do a Trig problem on my classpad 330
Press the keyboard button to display the soft keyboard on screen. By default it will show the tabs mth abc cat 2D
Tap the TRIG tab at the bottom of soft keyboard. The trigonometric functions will become available to you.
To make sure you are using the correct angle units look at the bottom of screen where it says Alg Standard Real Rad. If you use degrees instead of Rad it should display Deg.
To set the correct angle unit, press the Setting icon at the lowest left of screen and choose radian or degree and select decimal calculation if you need evaluated decimal results. Tap the set button to validate your choices.
Jun 16, 2010 | Casio ClassPad 300 Calculator
Convert degrees and minutes to decimal degrees
In the main menu screen press the Action menu, then Transformation submenu. At the bottom of the drop down list you have dms an toDMS.
Hope it helps.
Jul 13, 2009 | Casio ClassPad 300 Calculator
Conversion degree to degree,minute,second
ALL you need to do is use [Action] or [Interactive] menu --->[Transformation] --> [dms] (to convert from degrees, minutes, seconds to (degrees) form) or [toDMS] (for the opposite process).
Good luck, mates!
Jun 24, 2008 | Casio ClassPad 300 Calculator
Casio ClassPad 300 Calculator Logo
1,938 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
