Question about Whirlpool Heating & Cooling
In my ac there is a formation of ice layer on fins after using few hours
  • 384 Answers
Dear sir/madam
please check your air con unit is already clean if it,s ..and same problems is coming then it can be low refrigerant gas problem please contact to your service technician for further action refill gas.
hope answer the question
thank you
please vote!
Posted on Sep 06, 2010
My ac unit doesn't blow out cold air but everything else works do you know what the problem could be,it's a standup one
Probably needs a recharge... should be able to get the kits at a hardware store..... unless it was. Blowing cool when you started it and then it quit a few hours later... if that is the case place it in the bath tub and let the ice from moisture build up ( around the cooling coils high humidity will cause water to form freeze and layer up until it renders the ac useless until completely thawed... takes about 2 hrs... lots of water may run out as it thaws, that is why I suggested the tub... ps. This will happen to every ac and is not a big deal just a pain... and no don't use a hair dryer on it or warm water unless you don't like your ac... just time.
Jun 22, 2015 | AC Cars & Trucks
Ac not cold floor always wet passenger side.Every thing seems to work under hood all hoses are cold. pump comes on. fuses are good i made sure drain hose NOT plugged. blender seems to work the other opens...
You will find that the fins of the evaporator ( ac unit in car) are blocked up from gunk the floats around inside the cabin.. You may be able to clean it with an ac cleaner or compressed air. What is happening is that the gunk is forming ice which tells the TX valve that the temperature has been reached and so the ac compressor shuts off . The ice melts and the circle is repeated.. You may be tinkling as the ice breaks free of the fins and falls inside the ac box.
Oct 30, 2013 | 1998 Jeep Grand Cherokee
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
Aprox once a month, this is the second time, the fins and coils freeze up and i have to take the food out and unplug it for the nite to melt the ice, so it will get to zero again
You don't have to wait for a month to do it. Defrosting must be done weekly, to minimize that thick layer of freeze ice. You don't even need to unplug the AC cord, just push the defrost or set the defrost timer. After defrosting the refrigerator cycle operation will be back again.
Thanks for asking.
Jul 09, 2011 | Beverage-Air WTF48A (13.9 cu. ft.) Top...
My ice maker has suddnly quit making ice. I think it may b frozen up. How can I get the icemaker out to let it thaw. It is a Frigidaire Gallery side by side.thanks diane
My mom's will get an ice cube stuck in the ejecter. Done it 3 times already. I removed the ice bin and used her hair dryer. I just keep putting the hot air to it till I see the fins move all the way around. I put back the ice bucket and in a few hours it starts a makin ice again.
Jul 17, 2010 | Refrigerators
I have a lg fridge/freezer model grb218juda. The freezer is at the bottom and a thick layer of ice keeps forming which i have to scrape away monthly. the seal is not worn and this appliance is 3 years old
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jan 18, 2010 | Refrigerators
Ice formation on the fins- after about 20 minutes of putting it on, a comlete ice (snow) sheet forms on the fins-blocking airflow into the ac.
three possible prolems here 1 check the evaporator coil and filter to see if they are dirty and need to be cleaned dirt gets into the coil by by-passing the filter or the filter is no longer able to contain the dirt. 2 if there is a opening in your furnace that allows air to the furnance without going through the return air vent this could be a cause 3 low on freon in which a tech will be needed to check. Also check the outside unit and see if the coils have a lot of debris on them if so you can use a garden hose to clean them but make sure to have the power off and just spray the coils nothing else. Good luck
Dave
Oct 13, 2009 | Heating & Cooling
1.5T Voltas Vetris window AC. Ice formation
I think the more likely problem is that the unit is slightly short of gas\ refrigerant, which is a common cause of icing up evaporator coils and this sound you describe. First check that the air filter is clean. Another cause could be the defrost sensor is faulty, but I would think not. Some ice isn't actually a bad thing, but quite common as long as it doesn't form over too much of the coil, or get too thick.
Aug 15, 2009 | LG Heat cool Window Air Conditioner
Formation of ice on evaporator element
hi! there,
eventually ice freezing evaporator occured two factor you have
dirty fin evaporator and undercharge system.
1. undercharge can easily detected using clamp
ammeter clamp on one line of evaporator while running
read the amper the compare this to yuor service
manual the rated current of the compressor.
2.if the reading current is below the rared current on
manual or there is tag on the body of unit specified
rated current.your unit need to recharge.
if has the same current no change at all freon is still
good, this only need cleaning of eveporator fin.
clean this by pressurise water to purge out all debris
particle on fin tube of evaporator.
cracking sound usally made by blwer or fan
misalignement or distorted bearing blower .
regards have anice day dont forget to rate me.
Apr 10, 2009 | LG Heating & Cooling
Ice machine will not even start the ice making process. can get water out of the door with good presure but no ice
You either have a bad ice maker or a bad water valve. It really depends on what your model # is and brand.
Mar 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Heating & Cooling Logo
145 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
