Question about Janome Memory Craft 4000 Sewing Machine
Stops sewing I have a MC4000... I will be sewing along just fine and then it just stops sewing... no lights go out and the power is still on but it stops sewing and I have too let off the presser foot for a second and it starts sewing again.. I is happening all the time....
  • Janome Master
  • 1,388 Answers
Sounds like the motor is stressing and a cut-off is operating to protect from overheating........ensure the bobbin area under the needle plate is clean and clear of lint, and that there is no thread jammed around in this area, also at the take-up arm and the cams at the far left of the upper shaftnear the needlearm.........if there is thread wrapped around anything, unwind it VERY CAREFULLY .....DO NOT pull and break it, be patient and move the handwheel gently in reverse while gripping the trapped thread, working it free slowly.
Of course it may be that the motor is old and needing a replacement, but as this machine is quite elderly and may have other complicating issues, you would be best to have someone take a look at it for the best decision of fix or replace, if it comes to that point.
Posted on May 30, 2008
My new home mc4000 is only sewing in reverse
try turning the tension wheel in the center of the belt wheel. Have you changed belts recently. Also there should be 2 plugs for the machine motor, did these get switched?
Jul 29, 2017 | New Home Sewing Machines
Janome MC4000 occasionally thread comes out of take up lever while sewing.
the thread take up lever needs to be closed just a little, take a small piece of fabric and put it over the take up lever and use a pair of pliers to close the take up lever just a little and see if that helps the thread to stop coming out of the take up lever. ( the fabric is to keep the take up lever from getting scratched up, because of the pliers)
Apr 29, 2014 | Janome Sewing Machines
Singer stylist 534 sometimes when you stop won't start without turning balance wheel
Yes this is normal especialy with heavier fabrics. It allows more control so you build up speed gently. It is also related the limited power of the motor.
Mar 01, 2013 | Sewing Machines
I need a replacement Foot F No 822804004 for my memory craft MC4000
try ebay as people often sell their spare feet when they upgrade
Sep 11, 2010 | Janome Memory Craft 4000 Sewing Machine
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
Mar 15, 2009 | Janome Memory Craft 4000 Sewing Machine
I need a new Motherboard for my MC4000. Where can I find one?
Try here, https://www.sewingpartsonline.com/janome-mc4000-sewing-machine-parts.aspx or try Janome them self .
Mar 07, 2018 | Janome Memory Craft 4000 Sewing Machine
Replacing light bulb on mc4000
takes a special bulb which costs around $10 U.S. Easy to change Just pull out and reinsert in proper position.
Sewman7
Apr 28, 2008 | Janome Memory Craft 4000 Sewing Machine
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Sewing Machines Logo
136 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
