Canon ir 1022 is displaying "paper jam open the left cover " but there is no paper hanging or hooking up anywhere in the machine. pls help solving this problem
mstr2kx
  • 96 Answers
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Posted on Mar 20, 2007
JayBlair
  • 328 Answers
SOURCE: "document jammed" but no paper in the machine
There are a few sensors in the paper path which can easilt dislodged when pulling paper to rapidly from unit. Check all sensor flags and make sure they are moving freely.
Posted on Aug 10, 2007
Logjam
  • 159 Answers
SOURCE: fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Posted on Dec 24, 2007
SOURCE: "Offline"
which cover are you opening? You must pull open the bottom cover not the one under the keyboard. It's the bottom front cover not the top front cover.
Posted on Mar 03, 2008
SOURCE: canon 2060p message check/cover paper
there is a little white piece of plastic that gets stuck when you put in or take out toner catridges when not in the right position it cause that notification thank you again
Posted on Oct 16, 2008
How can i fix paper jam, close left cover or drawer cover ir 2016 canon
hi . be sure there is no paper jam inside the machine . turn off and on if problem persist maybe some of the flag sensors maybe stuck.
Mar 23, 2016 | Canon iR 2016i Black and White Copier
How do i fix power on paper jam on canon ir 3035 copier?
Probably one of the sensors on the papers way through the machine is out of position,or not working
Mar 05, 2015 | Canon Office Equipment & Supplies
Canon ir2016 jams papers under registration clutch. the clutch runs on power up but does not run when copig or printing help
This seems to be a common problem for the Canon ir 20 xx series machines. The problem is having machine indicating paper jams on the left hand side of the machine. When you open the left cover you do sometimes find paper stuck on entering the fuser unit. The main problem, and loads of these machines with these problems have been fixed, are the half moon pickup rollers! Clean the pickup rollers or even better, replace them and you will get the machine working 100%!! To confirm this try copying from the machine using the manual feed tray. You will never get a paper jam. This fault is due to incorrect pickup resulting in timing problem and thus getting paper jams! Good luck!
Mar 10, 2014 | Office Equipment & Supplies
Am repairing a canon ir1020 which shows paper jam for any single copy.though paper is completely delivered out of the fuser ,but the red in response to paper jam still flashes.I need an assistance.
Sounds like the fixing exit sensor flag is missing or broken. I would look into that and just a note... I had a strange jamming problem with one as well. It turned out to be the registration clutch. I cleaned the clutch and it worked......
Sep 01, 2012 | Canon IR-1022 Copier
Canon ir 2270 having a problem of paper jam but it doesnt show any error code can you help me solve this problem. by Fredy Gabriel
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
Jun 08, 2011 | Canon imageRUNNER 2270 Copier
How to solve 2side paper jam its in continue but 1 side is working good...how to solve this problem? its ir 400 canon machine
open the front cover and clean the duplex rollers with alcohol and dry it.
Also, if you have stand for these copier, on the left side of the stand there is opening on top of stand where the copy is going when it copy second side, check for any opsticles in there.
Hope that helped
Aug 06, 2010 | Canon imageRUNNER 400S Copier
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Assembly
Mar 19, 2009 | Canon iR 2020i Laser Printer
I am receiving an error of canon ir 1210- rec.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Mar 15, 2009 | Canon imageRUNNER 1210 Copier
627 people viewed this question
k24674
