Question about Mitsubishi WD-52628 52" Projection HDTV
Lamp light is steady yellow. TV works fine otherwise.
  • Mitsubishi Master
  • 8,617 Answers
Order another lamp and have it on standby as the steady yellow light is telling you that the lamp has outlasted the normal rated useage hours so your lamp will fail without warning at any time.
Posted on May 13, 2008
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
I have a sony kds 55A2000 and my lamp went out so i replaced it. and it startes up fan goes on and off . and tv shuts down light still blinks red? My optical block is getting a light green yellow tint but...
Lamp Fan should not cut off and on it should run at all times when TV is Turned on.Lamp Fan is designed to run when set is turned on to Keep Lamp Cool otherwise Lamp will burn up.
Yes Bad optical unit block could also cause set to shut down.But most of them will Play but with Dots,Green yellow tinit or Big blue Spots
Jun 23, 2011 | Sony KDS55A2000 55" HDTV
Tv was working fine. turned it on, the green power light flashes. power it down and the power light is steady red and the lamp light flashed red
you need to replace the lamp This unit has 2 different LAMPS used, one is SQUARE and the other is ROUND.
Dec 18, 2010 | Zenith Z52SZ80 TV
MY LG MODEL RU52SZ30 ( 2003), HAS A YELLOW LIGHT SHOWING BELOW THE LAMP ICON. IS THE LAMP BAD? IT STILL LOOKS PRETTY GOOD ON SCREEN EXCEPT FOR THE A BLUE TINT AREA ON THE RIGHT SIDE OF THE SCREEN
Yes, the lamp is nearing the end of life when the lamp light is a steady orange (yellow). Order a new one and replace it. (When other parts of the lamp system fail, you will see a blinking red light.)
I hope this helps.
Oct 14, 2010 | LG RU52SZ30 52" Television
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Hello. I have a Zenith DLP Projection TV that I bought new from the store (possibly the display in the store) that has been working fine for 2 years. Just only a few weeks ago, the color seemed a...
Sounds like you need to replace your lamp and the tv will work fine until the new lamp goes out. I have had three lamps since Nov 2006 in mine and I have a notice coming up on my Panasonic saying I need to change the lamp right now. Which is strange, because before there was no warning, it worked fine and then when we went to turn it on again, it just did not work until the lamp was replaced.
Oct 05, 2008 | Televison & Video
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52628 52" Projection HDTV Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
