Question about Toshiba e-STUDIO166 Printer
When i try to use scan, it gives an error message with the heading "CFPSCN32". And the error is :- Failed to link to CFP scanning service (wilserve://127.0.0.1/CFPScanning/es166)
5 Suggested Answers
  • 5 Answers
SOURCE: i can't scan
hope this will help u about CANON MX310
http://canoncanada.custhelp.com/cgi-bin/canoncanada.cfg/php/enduser/std_alp.php?p_sid=Gk-ofu2j&p_accessibility=0&p_lva=&p_sp=&p_li=
Posted on Apr 29, 2008
  • 73 Answers
SOURCE: i installed recently HP officejet
Hi There, This is a known issue with this device. Please follow the below steps to fix this issue : Try to do a complete uninstall
*first step*
-run installation media (CD / Download) software
-select uninstall and on the process, select uninstall all hp softwares associated the with the device
-after uninstall , select restart later to reboot the computer later
-go to start > control panel > add/remove programs (XP) programs (Vista)
-uninstall any existing HP softwares (note: for hp computers, skip this process)
-restart later
*2nd step*
-open contents of the installation media
-if you're using the installation CD. go to my computer, select the drive which has your cd in (eg. E:/ , D:/ ) right click on the icon and select open / explore.
-if you're using a downloaded software, click on start and click on run (XP) startsearch (vista), on that box, type in the command ( %temp% ) and press enter. it will open up temporary files folder.
-locate the file that starts with 7z (eg. 7z001cs1) and open it and now you are in the contents of the installer
-on the contents of the installer, locate UTIL folder and open it then locate CCC and open it as well
(note: check your operating system if it is running on a 32-bit or 64-bit . you can check it going to start>control panel>system)
-on CCC folder , locate uninstall L1 (for 32-bit) uninstall L1 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
-on CCC folder , locate uninstall L2 (for 32-bit) uninstall L2 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
on CCC folder , locate uninstall L3 (for 32-bit) uninstall L3 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later (repeat uninstall L3 steps for 3 times)
**********important**********
(do not run uninstall L4)
contiunued in the next post ..............................
Posted on Nov 14, 2010
SOURCE: MFC-665CW Scanner keeps saying Connection Failed
I think I solve the issue for scanning so far. Here's what you do goto control panel -> Scanners and Cameras. Then right click into propertise, then check Specify your machine by address. It should already have the printer IP address listed in the box below. If not our can goto to your router and see the ip in the DHCP Client List .
After this I'm able to use the Control Center 3 scanning.
I think the problem was the NODE name list in the setting in my winxp pro does not match the actual NODE name the printer is using.
Posted on Jan 20, 2011
SOURCE: Failed to link to CFP
Failed to link to CFP Scanning service(Wilserve: / / 127.0.0.1/CFPScanning/es166)
Posted on Jun 28, 2012
Job failed because scan name is invalid
Hi Anonymous / Kenneth,
I assume you must have this problem sorted by now. ( 2012.)
Perhaps there's a firmware up grade you could look into?
Perhaps you must have to check this problem with your Xerox Concessionaire.
Good luck.
May 14, 2012 | Xerox Phaser 3635MFP/X Multifunction...
Jul 12, 2011 | Toshiba e-STUDIO166 Printer
MC9090/615. Why can't I connect to wireless network?
Did you initially set it up with a CAT 5 (RJ45) cable plugged in to you PC? If you didn't, you have to use a cable to set it up initially and then the wireless will work properly... this is why they usually provide a CAT 4 cable in the box. Read the instructions carefully. If all else fails, call the mfr;s toll free number for assistance or send them an e-mail under Contact on the support heading.
Apr 14, 2011 | Computers & Internet
SCANNER ERROR 12
tell me scan error 12
Oct 18, 2009 | HP LaserJet M1005 Printer
OpScan Insight 4 scanner error message
i have a problem in opscan4 insight
Problem;
top/bottom image quality
Mar 20, 2009 | Office Equipment & Supplies
Hp psc 1215 all in one
hello...
- yah you are right there are lots of way how to scan
- first is by clicking the scan button on your printer and if it is not functioning fine then it will give you "no scan options" error message
- 2nd is by using the solution center. then if the software is not installed properly then you can get "an error occured with communicating scanning" or "no hp device detected" error message
- 3rd is to use the scanner and camera under my computer or computer
-- if it is not working then try to troubleshoot the problem here are the links that will help you to fix the problem pls click this link:
- http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00704&dlc=en&product=412187
- http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00852647&dlc=en&product=412187
- http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00809848&dlc=en&product=412187
- i w
Jul 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again."
Yep. I also can't scan using the Samsung SCX-4200, which results in that error
''The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again.''
Richard Betambeau,
Reading, UK
May 20, 2008 | Office Equipment & Supplies
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Toshiba e-STUDIO166 Printer Logo
822 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
