Question about Philips 42FD9954 42 in. Plasma HDTV
Philips 42fd9954-175 My philips turns on for a few seconds then turns off and starts flashing a green light. i have checked all the wires and they are plugged correctly. The picture wont come on but it does this weird flash as if it would turn on, but then shuts off and blinks. I am not good with huge repairs but i would like to know exactly what is wrong with it. but please simple terms so i could try to fix this, im on a budget please. thanks
  • Anonymous Aug 05, 2008
    yeah i have the same problem,, philips 42" plasma,, i dont no how u fix this but i have figured out something that helps.......
    if u punch the screen as hard as u can whilst shouting ccccccuuuuuuuuuunnnnnnnnnnnnnnnttttttttttttttttttssssssssssssssssssssss
    at the top of ure voice, it does seem 2 help u relax
  • Anonymous Sep 25, 2008
    Hi- I have had the same problem with our TV 3 times in the past 18 months. I guess it is the power supply. We luckily bought the extended warranty through GE otherwise each repair would have cost around $1400! On the 3rd time they have determined that there is something else that is wearing the power supply down and the cost would be to much to fix so we are in the middle of getting a compensation from GE to replace our TV. I am glad to hear that we are not the only people with this problem! Hope this helps!
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
Posted on Jul 01, 2008
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
    i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
    May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
    Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
    my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
    Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
    I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
    MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
    Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
    Philips 32PT6441\37 will not turn on. Flashing
    You need the Horizontal Timing Kit for your TV. Chassis # is L04.1U AA can be found on the back of the TV. The part# is 4835 310 57673, Have a tv tech install this for you.!!!!
    Oct 17, 2009 | Philips 32PT6441/37 32" TV
    Panasonic PT-LB10SVU green light flashing,then orange,lamp light
    i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
    Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
    Philips 50PF9631D Plasma
    First step....check power supply components.....research
    similar Model & problem.................T.
    Mar 22, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
    Philips 42PF7220A/37 42" Plasma TV
    After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
    Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
    Philips 42FD9954 42 in. Plasma HDTV Logo
    285 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
