Question about Zenith B27A11Z 27" TV
Blurry text on 27-inch Zenith "Sentry 2"
Just got a used Zenith off craigslist. Although the front panel is damaged (must use remote to turn off and on), the image looks fine ... EXCEPT ... any text from DirecTV (info screens, TV guide, etc.) is awfully blurry. Is there some way to get that into focus? Is it a DirecTV problem or a TV problem? Like I said, the image looks fine. Text from a TV screen looks OK.
  • desertland Jan 04, 2009
    I have the same problem with an older Zenith (Z25X225) - blurry text on Directv menu. Otherwise seems fine.
    Money is tight these days - if I can make the TV last a little longer it would be great.
    How do I adjust the convergence?
If your still looking for answers ... I have the access sequence to get into the SERVICE mode ... where you can adjust convergence. send email to
atcs<at>optonline.net
Posted on Aug 12, 2008
I have had this problem before and restarting the reciever fixed it. Just push the red button under the front panel of your reciever, or unplug the reciever for a minute or so.
Posted on May 14, 2008
Zenith 27 inch text is blurry
This tv needed CRT Tube discharge.Take the tv aparts,take out the CRT video board,must plug it back in."Highvoltage becareful",find a wire with good insulations,grounded itself in with a screw from a steal frame.High voltage "Take that wire go close to the CRT tube without the video board connect in.Than u will hear a pop,that the highvoltage,just discarge ur CRT bad contamination.The tv should be clear now,after putting it back together again,getting it working.
Dec 30, 2010 | Zenith B27A11Z 27" TV
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
I HAVE A 15 YEAR OLD ZENITH 27 INCH TELEVISION (MODEL- SE 2719P). THE ONLY WAY TO TURN IT ON IS WITH THE REMOTE. AFTER THE POWER WENT OUT FOR 20 SECONDS, I TRIED TO TURN THE TV BACK ON & NOTHING...
Yes it is definitely time for a new tv. If you live near a populated area just go on your local craigslist and you can get great used televisions for quite cheap. I have seen nice 36" tv's sell for 50$ and less.
Thank you and good luck,
Lee
Aug 20, 2010 | Zenith Televison & Video
Zeith 27 inches 2001
You will need a Zenith remote with a menu button
There should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlocks the auto-program (change to 0)
May 28, 2008 | Zenith C27A24T 27" TV
2 Problems
this answer has given also to some one had the same problem.
"On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu." Good Luck
You can also get a user manual at the link below:
http://www.retrevo.com/s/Zenith-C27A24T-TVs-review-manual/id/277ag102/t/1-2/
Jan 20, 2008 | Zenith C27A24T 27" TV
Zenith 27 Inch Sentry 2 i think
yes let me know if you still need help on this one it is in factory defalt, i will look up service manual and let you know the codes to make it a regualr tv again, they have it set to display setting.
Oct 23, 2007 | Zenith B27A11Z 27" TV
Blue screen
try to solder any loose connection
Aug 15, 2007 | Zenith C27A24T 27" TV
Zenith B27A11Z 27" TV Logo
356 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
