Question about Samsung HM500JI 500 GB SATA Hard Drive
Hello! I'm trying to create three partitons on an external sata hdd, Samsung, model HM500JI. I succeed only to create one FAT32 partitons, but not NTFS. Can you help. Thank you !
    Problem Solver:
  • 17 Answers
What errors do yo get while creating NTFS partition?
Posted on Sep 06, 2010
  • marius2du Sep 06, 2010
    Windows cannot format the drive and Partiton Magic gives me the error #701.
  • Vaibhav Batra
    Vaibhav Batra Sep 06, 2010
    try to format the hard drive from command line
    format driveletter: /x /fs:ntfs
LaCie Rikiki USB 3.0 connection broken
Can you open the case and remove the HDD? I looked at the specs on the device and I didn't see what interface the drive is, I would assume it's a SATA, I don't know for sure. Can you ID it? You can get a USB 2.0 to IDE/SATA Adapter: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554 You can remove the HDD, here are some examples : http://www.ultraproducts.com/applications/category/category_slc.asp?CatId=2781&name=2.5
>>>>I found the specs on the HDD inside, it is a SATA, (samsung hm500ji) : http://www.newegg.com/Product/Product.aspx?Item=N82E16822152168 , You can use the adapter to remove data and erase HDD and return for replacement under warranty.
Dec 19, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
I brought a 250gb hdd for the xbox 360. The xbox 360 says that it is a unformatted storage device, the only thing i can do is formatted the hdd. but nothing happend I have formatted the thing 5 times....
Trying to format a large external USB or Firewire hard drive to the FAT32 file system? Can't do it? Only see an option for formatting the drive using the NTFS file format? Well if you answered yes any of those questions, then you're at the right place.
I was recently trying to format my 1 TB MyBook external hard drive in Windows XP to FAT32 instead of the overly forced-upon NTFS format. Why? Well because I needed to connect it to a NAS device and the NTFS permissions were causing the NAS not to be able to access the drive. Simple solution is to use FAT32, no security, no problems. Though it's sometimes useful to format a USB drive in NTFS format.
Also, formatting a drive in FAT or FAT32 will allow it to be read by other operating systems, such as Mac, Linux, and older versions of Windows such as Windows 98.
Unfortunately, Windows XP and Windows Server 2003 will only format a removable drive in FAT32 if it's less than 32GB! Hmmm...that pretty much cuts out ALL modern external hard drives!
However, Windows can format a drive that is larger than 32GB in FAT32, but you have to use the DOS command prompt. However, if you have a drive that is 1TB or larger, you may still get an error saying "The volume is too big for FAT32".
In that case, you can use a free program called SwissKnife that will allow you to format an external hard drive that is up to 2TB in size. Let's go through both methods. In case you are having problems getting your external hard drive to show up in Windows, read my article on how to change the drive letter for an external drive in Windows.
Format external drive in FAT32 using DOSOpen a command window by going to Start, then Run and typing in CMD.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
Mar 02, 2011 | Microsoft 20GB Hard Drive for Xbox 360
When I attached 2.5" SAMSUNG
You may have a driver mismatch ,your HD may require
USB 3.0 driver or Sata compatible MOBO
Feb 14, 2011 | Samsung HM500JI 500 GB SATA Hard Drive
My partner's 2.5" portable La
Hi ,
Don't despare , I solved the same problem this way :
The best way I can think to recover your data is to extract the HDD from it's box ( box will be lost ) and connect the drive directly inside your desktop , as secundary .
You could also try a recovery tool , from here for instance
http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
If this doesn' t work , you finally could bring the drive to a specialized workplace where they will do the job for you but it will cost you then a lot of monney .
Best regards .
Jan 30, 2011 | Samsung HM500JI 500 GB SATA Hard Drive
HM500JI not recognized by computer (mac), a red flashes and it beeps.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 10, 2010 | Samsung HM500JI 500 GB SATA Hard Drive
How do I format my WD MyBook Elite to FAT32
Using FAT32 these days on a current OS will half the
HDD storing capabilities especially if your unit uses'
a SATA HDD , FAT32 speed compared to NTFS is
less than half and the compression tool on NTFS
are more compact and compile better , also FAT32
is used to apply an operating system not for external
storage and if you are using your external storage HDD for holding an operating system to the HDD
will be suspectable to contracting viruses and
putting your data at risk , since the external HDD
is static and does not run through the OS registry
Jan 28, 2010 | Western Digital My Book Essential Edition...
Samsung SP0802N External Case?
Hi, try this. This will work with your HD. 2.5"/3.5" EN391-S2HC USB 2.0/eSATA SATA HDD Dock w/Card Reader & Hub
Dec 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung HM500JI 500 GB SATA Hard Drive Logo
155 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
