Question about Mitsubishi WS-55809 55" Rear Projection Television
Connecting PS3 to Mitsubishi WS-55809
When I try to connect the PS3 using component video, I can only get a 480p connection. I want to get 1080i?
On the back of the TV you should find three sets of the component sockets, only one can produce 1080, the one that is labeled dtv (should be the one on the farthest right of the three sets).
Posted on May 20, 2008
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
Jun 07, 2014 | Mitsubishi WS-65313 65" Rear Projection...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
My ws-65611 always stay in 480i even with HD signal.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
Jan 25, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Ps3 problems
if the game doesn't support 1080i , then you could only get 480p.
did you try cod4 ?
May 21, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Hooking up my new PS3 to my five year old 55" Mitsubishi HDTV.
The Sony outputs 180P, not 1080i. There is a difference. I don't know what exactly, but Sony says 1080p is for superior.
Dec 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Geometry - Edges cut off
1)power on TV
2)Push menu-1-2-5-9 in quick succession
3)Use 4-5-6- to change colors
4)Use enter to blink / unblink cursor ( blink = move, unblink =
adjust )
5)Finished? = menu out to save changes
Please rate this solution......................................
Nov 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Oct 19, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
