Question about Acer Aspire One Netbook 8.9" Notebook
On my netbook my screen rotated sideways for no reason. How do I fix this?
    Problem Solver:
  • 17 Answers
Press and hold the ctrl and alt key then press either down or up arrow key to fix it.
Posted on Sep 06, 2010
How do I get screen right side up? I tried hitting ctrl alt and arrows and also tried right clicking the desktop. neither resulted in changing the screen from being sideways.
right click on your desktop(like the page you go on before going on internet and what not)
click graphic options
rotation
rotate 0 degrees
Mar 11, 2015 | Acer Aspire One AOD257-13478 mini...
My hisense screen wont rotate
Open Quick Settings and tap on Auto Rotate or go to Settings, System, Accessibility, Auto-rotate screen.
Jul 21, 2014 | HQRP AC Power Adapter micro USB Charging...
Screen sideways and computer is unresponsive
Reboot, then if responsive right click on desktop graphic options> rotate. If unresponsive still boot to safemode.
Sep 21, 2012 | HP Mini 1000 Netbook
My screen turned sideways
go to Control panel, and find Graphics / Video icon e.g. Intel, Nvidia etc.. There is an option to rotate 90 degrees clockwise or counterclockwise. Select that setting until your screen is turned in a normal way..
Aug 07, 2011 | HP Mini 1000 Netbook
My dog stepped on my hp mini and the screen is now sideways even after shutting it and restarting it.
It sounds like this should work for you. Press 'ctrl'+'atl'+the up arrow on your keyboard. You can use the same keys and change the arrow key pressed to rotate your screen any direction you need. This feature is usually used with LCD monitors so you can display a picture in portrait mode.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 03, 2011 | HP Mini 1000 Netbook
My problem is the screen the yahoo messenger goes sideways everything is sideways the icons too is on the rightside sideways even the start button ols help me fix this.thank you i still need to lift my...
You may try these steps. If you are facing a 90/180 degrees rotation issue with your displayed screen, this can be either due to a problem with your graphic card or a wrong manipulation of the hot keys of your keyboard. This problem can be easily fixed if you follow the steps below:
Solution 1
  • Step 1: With the Desktop screen displayed in front of you, use your mouse left-click to access the Graphic Properties? option
  • Step 2: Select the Rotation Tab
  • Step 3: Uncheck the box labeled Enable Rotation?
Solution 2
  • Step 1: With the Desktop screen displayed in front of you, use your mouses left-click to access the Properties? option
  • Step 2: Select the Parameters tab and click the “Advancedâ€? option
  • Step 3: From the displayed list, choose the name corresponding to your graphic card model
  • Step 4: Select the Rotateoption and change it to 0 degrees or to the “normalâ€? mode.
Solution 3
You can also make use of the hotkeys to change the rotation of your screen
Press CTRL+ALT Gr+Up/Down/Left/Right arrows
Solution 4
If none of the above solutions has solved your problem, this might be due to a bad configuration of your graphic card. I will strongly suggest you to contact a computer technician to fix this issue.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..." google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Jan 23, 2011 | Gateway Computers & Internet
My inspiron 1012 has rotated the screen by 90 degrees,so the display is sideways and the mouse responses are the opposite. Had the laptop 2 months with no problems,please help
Hi... hard time to re positioning your screen... click on right mouse botton then choose graphics property then display setting, you will see a rotation setting.. choose 0 degree's position,.. but you may have to read on the side ..it tricky for the mouse... with patience you will do it ...good luck
Oct 20, 2010 | Dell Inspiron Mini 1012 Netbook...
My netbook display screen for the desktop is flipped sideways how do I fix it? I have rebooted it 3x
It sounds like you have the screen flipped (portrait for landscape). If you have XP, you will need to look at the display properties. I believe this is Start > Settings > Control Panel > Display > Settings. Then click on the Advanced tab. Look for a rotate screen option. (It may also be available from right clicking on the desktop - look for Display.)
If you upgraded to Win7, right click on the desktop, choose Screen Resolution and you'll find a line with a drop-down menu for Orientation.
I hope this helps.
Apr 22, 2010 | Acer Aspire 3000 Notebook
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
LAPTOP PROBLEM
hold down alt & ctrl keys and press the up arrow and that should sort it out
Mar 16, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
540 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
