Question about StrandWare Label Matrix 32 Full Version for PC
How to convert barcode with ext file QDF to prn or text files ?
I require a .prn file for my cx400 for my software support person to design the barcode string to be used for my software to create the barcodes. my barcode printer is Sato CX400 & the software I am...
HI ...
1.I am using Sato CX400.my printer problem is when i give Command for printing copy (default by prn file one copy) but print out two copy and i wastage lots of label .so please help me about my problem.
2. i have sato Cx400 two printer but in both printer font is Bold & another is UN bold.so how make both printer setting same
Please help me by mail (bvionline@yahoo.co.in)
Thanking You
Jun 21, 2011 | SATO CX400 Thermal Label Printer
How to open files with extensions *.prn
right click on the file and select open with and you can select any text viewer like notepad,wordpad etc.
Sep 07, 2010 | Computers & Internet
HOW CAN I PRINT FOLDER CONTENTS SIMILLAR TO THE DOS CAOMMAND TREE > PRN
Go to start button. In the start menu click RUN and in the box that opens type "cmd"
In the CLI go to the directory of the folder whose content you want to print and type the following and press enter to create list.txt file first before printing.
dir /b /s /on >list.txt
This will give you a text file (list.txt) in the folder, that you
can manipulate, print etc. in a text editor or
word processor. In order to redirect the output
directly to your printer, instead of a text file, type:
dir /b /s /on >prn
Aug 25, 2010 | Microsoft Computers & Internet
WANT PRN FILE FOR BARCODE LABEL DESIGN
HOE TO DESIGN A PRN FILE FOR ZEBRA TLP 2844
Jun 03, 2010 | SATO CX400 Thermal Label Printer
How can I Convert my Image Files to Text Files? i have an Image file and i want to convert it to Doc. or Text files
hi...!! if your image files are pdf file, then you'll hve to install "pdf to text file" software in your pc. then after you will be able to convert your image file to text doc....!!
all the best
Oct 10, 2009 | Equisys Zetafax Document Conversion Add-On...
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
Please help abt VB6 code for SATO CX400 printer
just make prn file or by crystal report
call me on 9974985001
Feb 04, 2009 | SATO CX400 Thermal Label Printer
When I try to open a Quicken Backup QDF file, a Microsoft Offrice screen pops up. A program that we do not have. HELP!
if you need to open a QDF file
you need to install Snapform Viewer you can log on to the following link
http://www.snapform.com/download-viewer.html
click on windows and install the software
Jun 11, 2008 | Computers & Internet
StrandWare Label Matrix 32 Full Version for PC Logo
231 people viewed this question
Top StrandWare Computers & Internet Experts
David Payne
David Payne
Are you a StrandWare Computer and Internet Expert? Answer questions, earn points and help others
