Question about Whirlpool GEQ9800P Electric Dryer
No Power I replaced the heating coil in my Whirlpool dryer since the element was burnt in too, replaced all the wires appropriately had the numbered, but now the dryer acts as though there is no power. i checkd at the pigtail and have 240V . Before replacing the element the machine would run but wouldn't heat, now nothing??????
    President:
  • Whirlpool Master
  • 2,651 Answers
Look for an "open" thermostat either on the heater can, or a thermal fuse has gone bad, probably shorted out when the element broke.
Posted on May 13, 2008
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
Dryer want heat up what's problem
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it. Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryerOnce you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it, thanks to parts direct
May 31, 2011 | Maytag Neptune MDE6800 Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
I have a GE profile 3 years old. It won't heat
There are many things that can cause a no heat symptom in an electric dryer, here is a list of possible causes in order of likelihood or ease of access.
1. An open fuse/breaker in the house fuse panel.
There are 2 fuses or breakers for the dryer, both must be good in order for the dryer to function properly. If one is open, it is possible for the dryer to run but not generate heat. In the case of breakers, try resetting them as sometimes one of the two can open but not physically tip the mechanical lever.
2. An open thermal fuse in the dryer.
Some models use a thermal safety limiter or thermal fuse which could open the circuit to the heat element. These are used to prevent a runaway or over heat condition and are often found mounted to the blower or heater element housing (see the links below for examples). These devices are a fairly current development and may not be found on very old dryers.
Note: If this is the cause of your current problem (pardon the pun), I strongly suggest you check the vent for obstructions and ensure its length meets the manufacturers recommended limitations, the shorted the better. Failure of this part could be the first indication of a potential fire hazard in the dryer!
3. The element coil is burnt out.
Dryer elements are bare wires coiled like springs, when they fail the wire will break opening the circuit. This breakage could be intermittent, only opening as the element expands as it heats. Sometimes the element coil has to be physically checked for breakages, especially where the coil goes through ceramic insulator which could hide a breakage from plain view. Depending on the brand and style, the replacement element may be just the coiled wire that has to be mounted into the original element housing. On other models the element assembly comes already mounted on a frame that then in installed into the element housing or directly into the dryer. Whichever the case, the element coil has to be replaced not just joined together using connectors.
4. A burnt wire or wire connector. Replace the burnt wire connector and/or wire and inspect the component terminal it was attached to. If any sign of charring or discoloration are visible on the component's terminal or repeated failures occur at that same location, replace the component the terminal is part of. Such items can include the main power junction terminal block (very common), thermodiscs (thermostats), heat selector switch, centrifugal switch (on the motor) or the timer.
Feb 20, 2010 | GE Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
I have a whirlpool dryer. What is a element on the dryer.
The Element you ask about is normally called the Heating Element or Heating Coil. It is what heats up, then the blower blows air over the heated coils to dry your clothes.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, Hope this helps Please rate me, Thank you
Dec 31, 2009 | Dryers
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
I have a maytag model 747g dryer. I dryer tumbles
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
Jul 17, 2009 | Dryers
Dryer will spin but won't heat up
Hi
Things that could stop a electric dryer from heating:
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
Things that could stop a gas dryer from heating:
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Whirlpool Dryers
My whirlpool dryer has no heat. the drum turns.
Your issue is;
"my whirlpool dryer has no heat. the drum turns."
Based on the information provided above, I am unable to access my database to provide you with exacting information. A valid model number was not provided. However, I have provided some common solutions to help guide you in your search.
This information is for an electric, generic model dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
This link shows disassembly of a version 2 Whirlpool dryer:
http://www.repairclinic.com/0100_16.asp
Heating element
Thermal fuse
Wiring
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 23, 2008 | Whirlpool Dryers
Whirlpool GEQ9800P Electric Dryer Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
