Question about Dell Dimension 4700 PC Desktop
You have to put a lot of weight on the heat sync for it to boot up
    Scholar:
  • 181 Answers
I would assume that it's the cpu heatsink? Actually, it's a bad thing to put extra weight on the heatsink for it may damage the processor. The spring and locking mechanism of the heatsink is just enough to transfer the heat from the processor to the heatsink. Problem maybe on your processor not properly seated on the slot. Remove the heatsink assembly, and release or remove the processor from the slot. Check if there's a foreign object in the slot, a brush will do the cleaning. Reinstall the processor and the heatsink assembly.
Posted on Sep 13, 2010
How do I repair the E74 error on the xbox 360
E74 - This error is caused by a cold solder joint under the GPU, (H)ANA-chip or in between. Mostly it is one of the outer solder balls on the side facing the (H)ANA chip so a shim increases the chanced of success quite a bit. Can also be a component that is missing or damaged so look for missing parts near the GPU and the (H)ANA chip. Xbox 360 Error Codes Explained and How to Fix Them
Aug 13, 2015 | Microsoft Xbox 360 Console
Do i need to put weight in my saturn in winter time
No weight needed, but will always help the back end from sliding . If you have good tires and lots of gas, saturns are ok in the snow. Cheers from Nova Scotia!
Jan 22, 2013 | 2001 Saturn L-Series
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
Power will only stay 0n for a few sec and then shuts off
Hi,the problem with your ps3 is a heat sync failure,it's a common problem with the ps3,however,here is a detailed solution to help you out;
You have to disassemble the ps3 first, (hint) there is a srew were your rubber boot is on the bottom were it stands up remove this srew but you my have to get a star bit with a hole in the center of it. 2. After removing the cover then sides to the screw,lift the cover to remove all visible screws in the second cover.
3. Lift the second cover in a hinged motion to the front of the ps3 be careful not to pull the hidden carbon wire underneath of the cover if done properly you will see the wire when you lift the cover. To release the wire you must lift gently on the black clip holding it and it will release with no problem.
4. You then lift the blue ray drive up and then dissconnect the wires to it. then remove the power pack which is to the left of the blue ray drive remember there are screws holding this down, remove the wires then remove this peice as well, then remove any remaining screws on the mother board cover except the large philip head screws holding the clips that are in a slant. lift the mother board out to reveil the fan on the bottom now remove the srews that are slanted. the fan will then seperat from the mother board. then clean both of the contacts on the mother board and fan with rubbing alcohol. then seperate the metal from the mother board.
attention; there will be a watch battery connected to the metal,disconnect from the mother board. gently lift up on the metal to seperate the mother board from the metal. At this point you must be extra careful not to move any of the parts on the mother board remove the rubber peices then cover the heat syncs so they dont melt use a heat gun that can reach a temp. of 350 degrees Cel heat for 15 sec on the three heat sinks with a distance of 1 inch or greater move the heat gun counter clockwise on the sensors. during this time the peice must be level or it will hurt the system. After heated you will then need to let cool for 15 min. then flip the board over and hit the exact same spots in the same steps. at this point your problem is solved. Make sure all the peices of rubber that was on the chips is put back in the right spots too.You then put the metal back on the systems mother board at this point clean the syncs again then apply the artic silver in a thin bead on two heat syncs note not too much and not to little just enough to cover the syncs with a thin coat then connect to the fan. reconnect the fan then put the screws back in that holds them together then reattach the power supply but dont srew it down then remove the srews on the fan moter then remove it plug in your system switch it on stand by then press the sensor pad metal to start the system note this will not hurt your system this causes the artic silver to soder the heat syncs together only do this till you see a orange light come from the board near the fan then shut the system down then reattach the fan and reassemble.
Take care
Jun 19, 2010 | Sony Playstation 3 (PS3) Console
Dell Demension runs great but loud fan noise that takes a long time to shut down. What going wrong?
I had a similar problem with excessive fan noise on my Dell Dimension 5150. The solution was to replace the worn heat sync compound that was between the cpu and the heat sync itself. (£0.99 ebay)
Jul 10, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Jeep Grand Cherokee - can't get axle nut off
put car weight on wheel. i have use a electric impact wrench.those drive axle is on there.they have up to 170 to 180 ft lbs torque.make sure you are using 1/2 break bar and 1/2 socket made for the axle nut.
May 07, 2009 | 1994 Jeep Grand Cherokee
Wii fit board wont sync
get a new board or get it fixed,
try different batteries
dont put any unessessary weight on it
dont stomp on it or jump
be gentle with it
get a new peice so no re-scyn
make sure its not too close too the wii
Apr 11, 2009 | Video Game Consoles & Games
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
1.6 gtd driveshaft weight.
cut it off and dont worry about it.put on a new boot clean greese.you will not notice anything with that off the axel.i have done it many times
Jun 22, 2008 | 1991 Volkswagen Golf
Dell Dimension 4700 PC Desktop Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
