Question about Nokia 1209 Cell Phone
My nokia 1209 has ok ringer but there is no proper sound of ring tones
  • 3 Answers
Contect service
Posted on Sep 07, 2010
Not ringing
Nokia 1209 Cell Phone low ringer sound
Aug 29, 2013 | Nokia 1209 Cell Phone
Nokia 1209 ringer low sond
Go to setting and then to Tone setting and then Select the maximum Volume for the Ringing tone.
Nov 13, 2011 | Nokia 1209 Cell Phone
Sir, My Nokia model 1209, Model RH -105. Asking for Security code . Gave 12345 .It is accepting . Ringtones not displaying.I was unable to get Ring tone . No sound .When going to tone setting it not...
Just Reset your phone it will solve the problem. method is *# 7780* it'll ask you your security code just insert it & press ok It'll solved.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 17, 2011 | Nokia 1209 Cell Phone
NO RINGER SOUND
check your tone setting, confirm that the ringing is set to ringing
or may be the profile is set to silent, press and hold # button to release the silent mode
Feb 14, 2011 | Nokia 1209 Cell Phone
I am facing problem regarding nokia 1209 ring tone, ring is not ringing when call comming
Just being thorough, double check your settings, as follows; Menu, then choose Settings, then Sounds, then Ringers. You should be able to scroll through the ring options for volume levels to re-set your ringer; your phone may have a button on the outside, opposite side of where your charger attaches, & when you press this by mistake, it turns off the ringer (if that is what is on your model, because it is on one of mine, same brand, different model) I know it is a rather odd place for a silencer, but check this first, & then just call the cell from another phone, if you are able, & if that re-sets it, problem solved. Barring that, you may have a software issue, so your best option for highest quality results would be to go see your cell provider (better with a heads-up call/or an appointment so they have time for a bit of research, as it minimizes the time you have to be there) & they can probably provide replacement software, direct download from the manufacturer. Not only will they more likely have all the docking equipment needed, but you wont end up with extra data downloaded onto your computer that is difficult to remove without damaging your systems.
I hope this helped in some way, and best of luck to you and your through the coming Holidays! gms
Nov 17, 2010 | Nokia 1209 Cell Phone
No ringtone
First Option:
You Go to Phone Setting in ringtone setting and check the Ring tone Setting If Ring tone Setting Ok But Not Ringe tone So
Secne Option:
Your Phone Ringer Default So Please change Ringer
And Ringing Problem will Solved Quickly
Aug 15, 2010 | Nokia 1100
Nokia 1209 ringing tone on & swith off problem
This problem cause very frequently.just follow this......Press Menu>>>select Setting>>>press Factory Setting using up or down key>>> Reset it by using the code 12345/the code you are already in use....1000% OK.thanks for your reply
Aug 08, 2010 | Nokia 1209 Cell Phone
Nokia 1110i incoming call is not ringing
Your Phone Ringer Default So Please change Ringer And Problem will solved .
thanks.
Jul 20, 2010 | Nokia 1110 Cellular Phone
Ringar is not working plis help
ok first you need to check to see if your phone plays any tones at all .
if so you most likely have your ringer turned off. go to menu then settings then sounds. in sounds select ring tone or ring volume.
you will need to check in this area of your phone. select a tone and check to see if your ringer is off.
if that is not the problem you may want to try a soft reset. this will reset your phone to factory settings.
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Nov 14, 2009 | Nokia 3220
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Nokia 1209 Cell Phone Logo
191 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
