Question about Acer Aspire 5610-4648 Notebook
I just shutdown my laptop before sleeping at night and next morning i saw some problem occur. when i just power on my laptop, there is no display in screen and also no beep sound of RAM. When i open to see what is going on inside it then i saw fan is running just for 2-3 seconds and after that it is going off. Many people told me that it may be problem of BIOS. Please give me solution what i should have to do. Model is: ACER Aspire 4530
    President:
  • 2,291 Answers
Put out ur batery for some time and then insert it again and then check , try to run the fan , push it to run
Posted on Sep 06, 2010
Tip
How to Shutdown or Turn off your Computer Properly
There's nothing wrong with powering your laptop, or desktop, down by clicking the Power button and letting it go into standby, sleep, or hibernate mode, much of the time. On your laptop, usually just tapping the Power Button will perform the same function as the following instructions.
When doing this, click on the 69966d5.jpg symbol just to the right of the Start button. This allows all open windows to be suspended properly, with current data saved. When you startup the next morning, your open programs will still be running in the background. Clicking on your logon will have your right back where you left off.
If you see the same symbol with the exclamation mark 15ca2e0.jpg, click and leave the computer alone, because it will be in the process of installing important updates before shutting down.
Nothing beats a complete "Shut Down" through the Start menu in the lower left-hand corner of your Windows screen. Mouse-over to the far right icon, and click on Shut Down in the popup window. All your open programs will be closed properly, data saved, and memory and cache cleared. This is like going to bed at night with nothing on your mind, sleeping soundly, and waking up refreshed in the morning.
Then, when the computer is powered up the next time, it will be operating at its optimum performance levels without being "bogged" down with excessive leftover garbage from previous sessions. It leaves you with a fresh start-up the next time you are ready to use your computer.
To summarize, tapping the Power button most of the time, and allowing the computer to enter sleep mode, is fine. Occasionally, do a complete Shut Down to clear everything out of memory. Your laptop/desktop will thank you...lol.
Regards, Bill
09-19-10
on Sep 19, 2010 | Computers & Internet
Acer Aspire 5750Z-4877 laptop powers off after morning boot-up
check and see if the cooling fan is running and make sure it is free of dust sounds like over heating shutting down for its own protection
Apr 30, 2017 | Computers & Internet
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
Hi my daughter used the mac last night same as usual. When i started it up this morning i only have screen saver plus mouse pointing device showing!!! Normal shutdown procedure was followed. thanks in...
I'd guess that it went into sleep mode rather than shutdown. Sometimes the screensaver can only be woken up by tapping the space bar..
If that doesn't do it, hold the power button down for 10 secs and this will force-shut the machine, then boot up as normal.
Regards
Jul 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hp dv9207us laptop motherboard troubleshooting
Look for the motherboard on ebay,,will be pretty cheap.
Jan 19, 2009 | HP Pavilion dv9000z Notebook
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
