Question about Averatec 3200 Notebook
Averatec 2300 laptop will not power on.
Sometimes it blinks for a split second. Other times it will not blink at all. Even though the blue power but stays lit the whole time
  • 3 more comments
  • averatecuser May 21, 2008
    O.k. I removed the ram chip. I still got a power light and a dvd drive click. I did all this after the laptop ran for a few days and quit again. Now It will not turn on again. Its been about five days now. I still get the blue power light and a quick green flash on the harddrive light but no boot up. Do you still believe it may be the ram? Or the Bio's chip?
    I did reboot w/o the ram and it did the same thing it is doing now. I get the blue power light and the dvd drive clicks. It is the only ram I have for this laptop. I will have to order a new one to test it.
  • averatecuser Jun 11, 2008
    O.k., I replaced the ram with two brand new sticks. I'm still getting the same problem. Power light comes on, I can plug a cooling fan into usb port and it runs but I am still not getting the unit to boot up.
  • cooldog45 Apr 21, 2009
    When I press the power button, the blue wifi and power light light up. The hard drive light blinks for a second and then nothing. I tried everything from taking the RAM out and all but nothing.
  • Anonymous Apr 28, 2009
    same as above averatec 2300
The problem is that the computer does not get enough power when you turn it on and that's why it doesn't boot.
Try to put a random CD in it and leave it there for an hour maybe two. By spinning the CD, more volts get through the mainboard. Then shut it down by pressing the power button and then press it again and see the results. If this wouldn't work the first time, try it again.
Posted on Aug 27, 2008
I got this Averatec 2300 from a friend when it quit on him. He removed the hard drive and left the "dead" notebook with me. I put a hard drive I had laying around in it and plugged it up to power and it booted up!! I could not get Windows XP to run in it (I don't have the original disk) so I loaded Ubuntu 10.04 in it. It booted up and ran great for a while, but them it just died... I could not get it to boot again from the CD or from the HD. I removed the HD, played around with other HD's and got nowhere. I set it aside and was going to throw it away, but I just tried the HD once again and the thing booted up again. I'm writing this post from the notebook right now. However, I don't know how long it will run and if I will ever get it to boot up again after it quits... I think there is something wrong with the power supply or that it overheats and stops. Perhaps both issues occur. I don't know what else to do to fix it. If I cannot find a power supply, I guess i'll just have to throw it away...
Posted on Jul 06, 2010
Had the same problem. Tried everything - see above commenst.Even put laptop into freezer.
Mine has to run on power saver mode, otherwise - crush.
If I still get the crush I let the laptop seat with both blue lights on (power and wireless) after about 2 hours lights go away and I can start again.
It is not the RAM. I changed it twice to two fresh stiks, I got new battery also.
It is something with power management. It used to get very hot and fan would spin like crazy.
I think some element in motherbord once gets overheated gives up.
I have ACER Extensa now.
Don't waist your money on fixing AVERATEC 2300 it is a good mashine for about first 3 month. It is a piece of junk after that.
Posted on Oct 29, 2008
Hi, sorry my bad English, I'm from Brazil and have the same problem But, firsts times, in boot, with no screen, the bios beeps 3 times, the power led on, the wireless led on when I turn on wireless, the caps, numlock and the other leds flash fast, but the screen don´t turn on and the note don´t start.
I open the note, unmount all parts, (also the monitor), to see if any componet was unpluged, but is´s aparently all normal. I mount all again, but the note don´t start yet.
This can be the BIOS chip? Is so, how I can reset the BIOS, to make a test? (the battery is sold in the motherboard).
Thanks a lot!
Posted on Jun 22, 2008
    Scholar:
  • 72 Answers
Doesn't sound like it's getting anywhere, so it's probably not your graphics chip. Most likely a problem with your BIOS or RAM. Sometimes the BIOS can get stuck thinking your machine is resuming from Standby which could cause this problem, but since this happened after your computer crashed I want to lead more towards the RAM. Let's start with that first.
Are you familiar with removing your laptop's RAM? If so, unplug the power cord, remove the battery, and take out your RAM. If you have two sticks take them both out. Then try booting the computer with just the power cord and no RAM installed. See if you get any response with that. If so, hold the power button to turn it off, unplug the power cord, and try booting with one RAM stick at a time. With this method you might be able to isolate the issue down to one stick.
If you aren't familiar with removing the RAM let me know and I'll give you some instructions.
Posted on May 13, 2008
  • Rick White
    Rick White May 21, 2008
    It sounds like the RAM. Did you try booting the machine both with the RAM removed and then with the RAM replaced? How many sticks of RAM are in your machine?
  • Rick White
    Rick White May 22, 2008
    Too bad you don't have two sticks to test for errors. No matter, I agree with you. I think ordering a new stick is your best plan of action for now. Try www.crucial.com to figure out what type of RAM your laptop takes. I would recommend purchasing from www.newegg.com. They have fabulous prices with great shipping. Keep us posted!
When you press power the blue light comes on and blinks 4 times and standby lights stay lit and powerlight never comes on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 01, 2015 | Hitachi P50T501 50 in. Plasma HDTV
I have a 42 inch philips lcd tv and it will not turn on. Tried unplugging it for 60 seconds and only the light will blink red sometimes and then blue sometimes. Do I change out the power source
Number of TV have a bad batch of capacitors on the power board. If you look like split mushrooms that is a bad sign. But there are kits if you know how to solder.
Oct 25, 2015 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
Panasonic Plasma TC-50PU54 LF21030116 Power light blinks 8 times When I attempt to power on it turns on for split second then shuts down. Is this fixable? thanks.
Yes. It is probably a problem with the internal power circuitry. Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Panasonic Televison & Video
Keeps turning off
Everytime I worked on this set I have found bad connections in the power supply or on one of the inverter transformers
Dec 31, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
TV won't stay on. Standby light flashes 5-10 seconds then shuts off. Just before this happened - it turned on , had good sound but the picture never lit up. Now it won't even turn on. I've...
Hello
Blinking of standby light in Sony sets are fault indication. You just count the exact number of blinks occur at on instance, say, after you switch On and OFF by its front panel power switch, not by remote control hanset. Just count it atleast 4 times, count it keenly and inform it to me, and let me reach to the nearest falult point; or sometimes to the exact point. OK.
Dec 06, 2010 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
Averatec 3200 Notebook Logo
1,824 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
