Question about One For All URC4220 Remote Control
No codes work :(
I have the URC-4220 remote and an Emerson 27" tv, ive tried all given codes including the one you provided in response to someone else (0171) and none work. please let me know of any progress on this problem. Thanks for your time.
    President:
  • 2,712 Answers
Emerson codes: 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 17, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
How to program a urc-4220 for an Emerson tv dvd combo EWO20D4
This is a little complicated but one of these code groups should work
0002, 0278 (for TV use 0624); 0294 (for TV use 0236); 0479 (for TV use 0463)
Dec 09, 2012 | Televison & Video
Tip
One For All URC-4220 Code Search
One For All URC-4220 Universal Remote Code Search
To program your One For All URC-4220 universal remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
___________________________________
One For All URC-4220 Manual
One For All URC-4220 Code List
One For All URC-4220 Code Entry
One For All URC-4220 Reassign Key
on May 30, 2010 | Televison & Video
Tip
One For All URC-4220 Code Entry To program your One For All URC-4220 remote...
To program your One For All URC-4220 remote control to operate your TV you can use the direct code entry function.
To enter for a code for your TV follow these steps:
  1. Turn on your TV.
  2. On the remote, press the TV key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the code list. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the TV and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
____________________________________
Need a romote code for HRS URC-383 for my emerson 27 inch flat screen.
If you are using Sky Remote then you can try to use these codes 0742, 0205 or 0206 for you Emerson TV which will work on all versions of the handset.
these are usually generic codes and may well work on the HRS URC-383 remote as well
Oct 04, 2009 | Emerson EWF2703 27" TV
Oneforall remote wont work with my dynex tv!!
I used 0463 for my 19 inch DYNEX LCD TV. It's the code for Emerson & Admiral. :)
Jul 23, 2009 | One For All URC-4021 Remote Control
Tip
I hope that helps.
on May 30, 2010 | One For All URC4220 Remote Control
Tip
  1. Turn on your TV.
I hope that helps.
Emerson TV codes for URC-4220
I e-mailed OneForAll, the manufacturer of my remote control, and asked them for a different code for an Emerson EWF2705 television. I received a reply back from them suggesting the code 0171. I just tried it out, and it worked perfectly. My suggestion is that if anyone is having a problem with their one for all remote, to e-mail customer service from the one for all website. It is:www.ofausa.com.
Mar 04, 2008 | One For All URC4220 Remote Control
One for all URC4220
go to one for all universal remotes
Feb 13, 2008 | One For All URC4220 Remote Control
Using my universal remote to control my iLo 27" Wide-Screen LCD TV
I have a ILO 27" TV Comcast had no suggestions for programming their remote. I went thru the ENTIRE code book and finally came up with one that worked: Emerson Code #0463 for my COMCAST universal remote.
Jul 14, 2007 | iLO V27DMBX Television
One For All URC4220 Remote Control Logo
54 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
