My lamp are fine it jus wont power up wat do i do buy a new power cord or wat
The bulb itself my not be connected, when i replaced mine it pushed the weak connector out the back, had to take the back of the tv off and fix the problem.
Im getting the same thing. try to turn on and nothing at all happends. no lights of any color or sound or anything.... i have the wd62327. i cant even find the fuse block to check the fuse on it. please help thanks in advance
I'm having the same problem, i think! After disconnecting the power source for a very long time (days) and reconnecting it, i get nothing! I mean nothing at all. No lights, sounds or anything. Could thins be a power supply issue? If so whats the approx. repair cost for such a item? thanks to all that help in advance :)
Can you describe exactly what happens when you unplug it for 5 minutes then plug it back in and then press power. Explain the sequence of events that happen if any.
Switched the lamp, makes an initial power on sound put doesnt turn on. Orange status light blinks.
