Question about Panasonic KX-T7730 Corded Phone
Good day. when i put the hand set down, it keeps playing a melody. please assist.
  • Panasonic Master
  • 2,460 Answers
Without picking up the handset, press "1".
This turns the BGM off.
Carl
Posted on Sep 06, 2010
How to turn off music when turning on tv
Yes it is possible. You should be able to set the melody to off, low, medium or high
I believe you can get to the setting by doing this:
  • Press the MENU button to display the on-screen menu.
  • Press the up or down button to select "Setup", then press the ENTER button.
  • Select "Melody" by pressing the up or down button, then press the ENTER button.
  • Select the setting you want (Off) by pressing the up or down button
    repeatedly.
  • Press the ENTER button.
  • Press the EXIT button to exit.
You can find the manual here: http://downloadcenter.samsung.com/content/UM/200804/20080401185600828_BN68-01507A-01Eng-0328.pdf
Page 24/25 is where it talks about the Melody setting.
Sep 10, 2014 | Samsung LA22A450 22 in. LCD TV
Tip
Turning off the Melody sound on a Samsung Television.
You have a Samsung television and you want to turn it on at night, and not wake up your house, or you are annoyed by the sound that the television makes when you turn the set on and off. Samsung incorporated a feature into the set that will play a melody to let you know that the set is either turning on or off, whichever the case may be.
If you want to turn off the melody you can follow the instructions below and that should take care of the annoying sound that is bugging you.
You may have a Samsung television and you remember when it had a melody when you turned it on and off and now that is gone. Well this tip can help you too. The same menu selection will allow you to enable the melody that is missing, and you can bring it back.
You can change the setting on your Samsung Television by selecting “Menu” then “Settings” and arrow down to “Melody”. There are four options; Off, Low, Medium, High. I personally would not select the high setting as it is very loud on my set. I guess if you have someone in your house that sneaks the television on and you want the loud melody to play, this could be a way of knowing when the set comes on. I hope that this helps you with your television issues and as always, Thank you for using FixYa.
I hope that you enjoy your television for years to come.
asnowman
on Mar 16, 2010 | Televison & Video
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
I want the keytone to be silent - how do I set it to silent?
You have to do the following:
Sound Profile
You can customize various sound profiles for your phone by
changing the sound settings.
1. In Idle mode, press the Menu soft key and select Settings
➔ Sound Profile.
2. Highlight one of the following sound profiles:
• Normal
• Silent
• Driving
• Outdoor
3. Press the Edit soft key to access the sound settings.
4. Press the Change soft key to change the "phone" option.
• To move between the various tabs, use the Left and Right Navigation
keys.
• To highlight individual options, use the Up and Down Navigation keys.
• To change the setting for a highlighted option, press Change ( ).
There you have these options:
– Keypad Tone: allows you to choose between Beep, Xylophone, and
Mute (no tone) for keystrokes on the phone.
– Power On Type: allows you to select the way in which the selected alert
is played when the phone is powered on.
• Melody: the phone sounds the selected melody.
• Vibration: the phone vibrates.
• Vibration & Melody: the phone vibrates and also plays the
melody.
• Mute: the phone neither vibrates nor plays a ringtone. The only
indication of a message is an alert on the display.
5. Press the Save soft key when you are finished.
Normal Profile
To access the available options for this sound profile, press the
Edit soft key.
keys.
• To save your changes, press the Save soft key.
This should do it.
If you still have some problems please download following manual and go to page 69 where you find all related info.
Propel Manual
.pdf
Hope it helped.
Nov 20, 2009 | Samsung Propel A767 Cell Phone
Cant get the dmtech lq17xts tv's freeview to work
General reset procedure for DM tech is:
1. Have Analogue station showing,
2. Press display button on remote,
3. With display info panel in view on screen, press 1 1 Line buttons on remote, this should bring up reset menu on left hand side of screen.
4. use up/down arrow buttons on remote to select either Reset or EEPROM then use right arrow button on remote to select the appropriate procedure
NB - on my set, selecting OFF the annoying melody that plays when the TV is turned ON/OFF diasbles Digital TV (Freeview). Turning ON the annoying melody makes DigiTV work again!
Jun 24, 2009 | Televison & Video
Ringtones fading in by default
You can try going to Sound profiles and choose a profile: "normal" or "outdoor" etc. and make sure that the Call alert type says "Melody" instead of "increasing melody". I have noticed that mine increases the melody for the first 2 seconds even with "melody" setting.
If that does not work, maybe try editing your tones so that the volume is twice as loud at the beginning of the tone. Good Luck!
May 14, 2009 | Samsung SGH-U600
Cit200
Adjusting the volume of the caller's voice
You can increase or decrease the volume of a caller's voice during a call. There are 5 volume levels for selection.
To adjust the volume, during a call: While the phone is off hook (i.e. dial tone can be heard), press Up or Down.
The display shows the current volume level. Press Up or Down again to adjust the volume.
Still can't find the most comfortable level?
Besides adjusting the volume on the handset, you might also need to adjust the volume on your PC in order to set the speaker to the most comfortable
volume.
To set your handset's ringing melodies and volume:
1. Press MENU.
2. Press Up or Down to select SOUNDS. Press OK.
3. Press Up or Down to select HANDSET. Press OK.
4. Press Left or Right to change the volume level. Press Down.
5. Press Left or Right to select the external melody. Press Down.
6. Press Left or Right to select the internal melody. Press OK to confirm when finished.
Nov 01, 2008 | Linksys CIT200 IP Wireless Phone
Setting a tone for text messages
This is easy. I don't mean to sound arrogant, sorry. follow these instructions: press the menu button/ go to/in settings/ the first tab is phone profiles/ press select/ options/ edit/ you will see three tabs at the top right of the screen, the phone with a speaker tab is highlighted/ go right one to the txt mssge icon, enter message alert type and choose the melody option, press o.k/ go down one section to the "message alert tone, press the options key/ change/ use my alert tone, this opens your files/ press right once to select memory card and choose the folder with the melody you want to use in it/ when you've highlighted the melody press options/ select. Next scroll down the page for the volume settings/ select whatever. You have now chose the melody for txt mssges. finally press options save. Job done. I know this is what you wanted. Good luck. Trevor
Oct 21, 2008 | Samsung SGH-G800 Cellular Phone
Panasonic KX-T7730 Corded Phone Logo
52 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
