I have a Noirot panel heater and I can get no response when I press the enter, mode, or program buttons. It seems to be locked, but there is supposed to be a lock symbol and there isn't. There is a small clock symbol in the left hand corner, which suggests it is on a timer of some kind. It is still heating up, but I have no control over it.
informatica
  • 1114 Answers
SOURCE: Panel Locked
Press and hold CLEAR/OFF for about 3 seconds to lock and unlock. Download manual on link below: http://www.abtelectronics.com/images/products/PDF_Files/SCA1000-SCA1001_om.pdf
Posted on Jul 27, 2007
  • 1694 Answers
SOURCE: Locked out of TV
Use two buttons on the tv at the same time, hold four seconds.
Try menu & power or vol up & chan up.........
Posted on Nov 04, 2007
hotuna
  • 288 Answers
SOURCE: Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Posted on Mar 05, 2008
SOURCE: biglou
my '96 had a similar triangular light,it was the lambda light which means something is not right. It could be major or minor , could be an O2 sensor. Only way to tell is to hook up to dignostic computer.Could be the gas cap not tightened properly.
Posted on Sep 03, 2008
  • 83 Answers
SOURCE: Clock/Timer
Is there a childlock feature that has been accidently turned on?
Have you got your manual for the appliance?
Such a feature would prove worthy around young and curious children.
Posted on Sep 14, 2008
Can I reprogram my keyless remote from my 1995 eldorado to my 1996 cadillac eldorado
AS programs can be altered I would have it checked out at a dealer service centre as they will need the keys and the vehicle to see if it can be done
Jan 11, 2014 | 1996 Cadillac Eldorado
Please call service
The most likely cause is either the fusing unit located in the right side door (orange in color) or a main motor lock. To determine what the trouble is, you need to enter the maintenance mode. On the control panel, press the "program * 6 keys in order. Press the right arrow key until service mode is displayed and press enter. If the display says heater error you have a bad fusing unit. If it says Rx motor, then the main motor is locking up. Check the drum and toner cartridge for motor lock problems.
Aug 01, 2012 | Muratec - MFX-1300 Copier
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Nov 05, 2010 | Pool & Spa
How do I program a Cadillac 2004 Deville remote key fob?
came across this, maybe this will help out...this is for analog gauges....
With the ignition in the "RUN" position (engine does not necessarily need to be running, but it will work either way).
Press OFF and WARMER (or the OFF and PASSENGER WARMER buttons) on climate control panel simultaneously. Instrument Panel Cluster (IPC) will light all telltales, then go blank. System is now in DIAGNOSTIC MODE. After diagnostic mode cycles through and stops, press FAN DOWN button until "RFA?" is displayed, then press FAN UP. If "RFA DATA?" is displayed, press FAN DOWN. If "RFA OVERRIDE?" is displayed press FAN UP button.
If "RFA S00 NO OVERRIDE" is displayed, press FAN DOWN. If "RFA S01 PROGRAM FOB #1" is displayed, press FAN UP button.
IPC will show "0" on right side of Drivers Information Center (DIC) display. Press WARMER button on the climate control unit until "99" is displayed.
Press and hold TRUNK button on the transmitter. While holding TRUNK button, press LOCK button and hold both buttons for a total of 3 seconds. Locks will cycle when programming is complete. If transmitter is not programmed within 30 seconds after entering "99" on the display, system will default and you must begin at step #2 again.
To program second transmitter, press FAN DOWN button until "RF S02 PROGRAM FOB #2" is displayed, then press FAN UP. Repeat step #4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET button.
__________________
Oct 30, 2010 | 2004 Cadillac Deville
How can i program my door lock code or find out what it is. on my 2000 limited edition explorer
FORD KEY PADS
  • Enter permanent factory code
  • Press the 1/2 button within 5 seconds to enter programming mode
  • Within 5 seconds enter new code, doors will lock, unlock to verify code, this erases previous codes remotes will also need to be programmed.
FORD KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
NOTE-I found that some Explorer/Mountaineers enter program mode after 5 times-not 8.
Here is the link for further info.
http://www.2carpros.com/how_to/how_to_reprogram_key_remote_fob.htm
Your factory code is on a card in the owners manual. If that is lost, access the control module in the cargo area behind the left cover panel.
You MIGHT be able to see the code printed on it, or you might need to pull it out in order to see it.
May 27, 2010 | 2002 Ford Explorer
I have a 7383-7 Noirot Melodie heater and no instruction manual
http://www.enviro-friendly.com/noirot-electric-panel-heaters.shtml
The above site for Noirot (if you scroll down to the bottom of the page) has Instuction Manuals that you can either READ or Download.
Mar 28, 2010 | Heating & Cooling
Programing a new remote
Use these instuctions if your Deville has an Analog Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Panel (CCP) simultaneously.
(Instrument Panel Cluster (IPC) will light all telltales, then go blank) System is now in diagnostic mode.
Press PASSENGER COOLER button until “RFA” is displayed, then press FAN UP.
If “RFA DATA” is displayed, press FAN DOWN.
If “RFA OVERRIDE” is displayed, press FAN UP.
2. If “RFA 500 NO OVERRIDE” is displayed, press FAN DOWN.
If “RFA 501 PROGRAM FOB #1” is displayed, Press FAN UP.
3. IPC will show “0” on right side of Driver Information Center (DIC) display.
Press warmer button on climate control unit until “99” is displayed.
4. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not
programmed within 30 seconds after entering “99” override display, system will default and you must begin again at
step 2.
5. To program a second remote, press FAN DOWN button until “RFA 502 PROGRAM FOB #2” is displayed, then press
FAN UP. Repeat step 4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET.
Use these instructions if your DeVille has a Digital Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Center (CCC) simultaneously. Instrument Panel Cluster (IPC) will
light all telltales, go blank then enter DIAGNOSTIC
MODE. Press FAN DOW button to scroll through system until
“RFA” is displayed, then press FAN UP button. Press FAN DOWN button until “RFA OVERRIDE” is displayed, then
press FAN UP button. When “NO OVRD RF 500” is displayed, then press FAN UP button.
2. When “PGM FOBL 501” is displayed, press WARM button and “99” will be displayed in left upper corner of IPC just
below odometer. System is now ready to program remote.
3. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
step 2.)
4. To program second remote, pres FAN UP button until “PGM FOB2 502” is displayed, then follow steps 2 and 3 to
program second remote.
To exit system, press RECIRC or RESET buttons.
Disclaimer
Apr 25, 2009 | 1998 Cadillac DeVille
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Heating & Cooling Logo
186 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
