I have an HEC1050w washing mashine that can only be just over a year old and it has just stopped mid cycle with the Door lock light flashing 7 times which is a motor overheat error. Could this be warn brushes on the motor? The machine is used probably 3 times a week. Any help would be appreciated Thank you Kevin
  • codeye716 Sep 06, 2010
    Thank you Caroldon
    I have lightened the load but the problem persists. I will check the capacitor in the morning,
  • 2,272 Answers
Try replacing the capacitor But if problem is same then its faulty/weak motor causing this problem.Replace the motor and it should solve the problem. Also see if the motor connection wire is cracked or got cut in between,If that is the case then the motor connecting wire is the problem causing this. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 07, 2010
  • Washing Mach... Master
  • 17,130 Answers
Check for friction on the drive, you can look from belt to turn the motor physically and check if therer is a tight drive fitting possible with dirt build up into the system.
Secondly check the load you are using, if so try with a lighter load just to confirm our doubts.
If so there can be errors of faulty motor, if with the capacitor then check if the capactior is bad.
Posted on Sep 06, 2010
Why does my 5 year old machine keep stopping mid-cycle?
Check the door sensor and clean it. Or one or more(i believe there are three) of your tub sensors may be bad.
Sep 11, 2015 | Washing Machines
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Duet Sport stopped in mid cycle
Read the Manuel and see if they offer an over ride, first.
Since you already tried rebooting the machine, I won't suggest that!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
