Question about Toshiba Televison & Video
Toshiba DVD VIDEO player SD-3990SU (SD-3990SC)2005 no longer playing in color; can find no solution or setting that will adjust this. Puchased player in 2005. Thank you for any help you can provide!
    Problem Solver:
  • 15 Answers
Have you exchanged your A/V cable? could be faulty cable.
Posted on Jun 12, 2008
When loading cd, it says bad
It's likely there is dust on the CD player lens. Many DVD units have two lens units, one for DVD's and the other for CD. You will to clean the CD one.
Mar 26, 2017 | Toshiba Televison & Video
Set up to play dvd movie on TV
You just need an RCA cable. Find the output from your dvd and connect to the input of your tv. The cable has three connectors in three colors...red/white/yellow. Res and white is audio and yellow is the video.
Dec 22, 2007 | Televison & Video
I have a DVD in my SD 3990SU - it won't play and the door won't open using the remote or the button on the front of the unit. is there an alternate way to manually open the cd loader.
You will need to open the set and manually move the motor drive to manually shift the drive to release the Cd.
Now check the voltage to the drive and also check the power, the main board drive circuit, the motor .Check the control signals to the motor drive , if absent the processsor control is faulty.If present the drive IC is faulty
Sep 26, 2010 | Toshiba SD-V290 DVD Player/VCR
I just got a toshiba theaterview sd dolby digital
That particular TV has both "component video" and standard video inputs. The DVD player might have a component video output (it will be three separate connectors of three different colors.) You will need a component video patch cable available at most electronics stores. If your DVD player doesn't have that input then use the standard video connector, yellow wire connects the video out on the DVD player to the Video input on the TV. The red and white wires are the left and right stereo audio connections they also make a cable for that. It will be color coded so make sure you match the codes from the output to the input on the TV. This set has two video inputs, you will get your best resolution if you use them instead of a "channel" input.
You will need the remote to select the video 1 or video 2 inputs. You can connect your DVD player and your game at the same time. Just use video 1 for the DVD and video 2 for the game. They require the yellow, red and white connector cables. Just follow the color code and match the colors with the jacks on the TV and other units. There is actually a third video input Video 3 behind the little door on the front panel. That would be convenient for the game if you want to remove it easily when not in use.
Push the menu button on the remote (big button in the middle) go to the video function and select either Video 1 for your DVD, Video 2 or 3 for your game.
The correct video input for what you want to view is important. Also if you don't have the user's manual it's available for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2003/32A33_32_36A43%28E%29_A.pdf
You might also need to download an Adobe Viewer which allows you to read .pdf files.
That is also available for free at:
http://get.adobe.com/reader/
If you already have malware protection (viruses and the like) un-check the MacAfee box so you don't download that too.
Zashiban
Jun 04, 2010 | Toshiba 32A43 32" TV
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
No color
Make sure your av channel say`s av2 not av2s as this can give b/w pic.hope this is of some help
Mar 31, 2009 | Toshiba SD-6915 Multi-disc DVD Player
TOSHIBA SD-1600 WILL NOT PLAY DVD+R RECORDIBLE DISC.
wer i can find the model of the toshiba dynabook video driver?
Dec 22, 2008 | Toshiba SD-1600
DVD plays with sound but no picture
Have you checked the unit on another input or another set to eleminate the video input? also try the video cable. If theres sound and no video and you tryed then the video output amp in the player has a problem and the only way to fix this would be with a schematic and a scope to trace out the video signal. Good luck
May 25, 2006 | Toshiba SD-230 DVD Player
Televison & Video Logo
211 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
