Question about Dell OptiPlex GX260 PC Desktop
I have dell optiplex gx260 when i power it on its not respond and the fans not work only the light of power switch is being orange its flash, that it being on then off continously. please help me...
  • Dell Master
  • 27,725 Answers
First test your PSU or replace it then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive or
replace them they are probably old and faulty ?
good luck
Posted on Sep 06, 2010
My Dell Optiplex gx260 Pentium 4 Flat CPU doesn't Display anything, and Power light is Orange.. Please help me out
You say the power light is orange--I'm assuming that you mean the monitor.
This indicates the monitor is not receiving a signal from the computer.
Assuming that the computer actually powers up (fan runs, you can hear the hard drive being accessed, etc) then your problem lies in the video card.
If, on startup, you do see the BIOS info and maybe even the Windows splash screen before your monitor goes dark, then the problem lies in the video card drivers. In this case, starting in safe mode will work and allow you to download and install new drivers.
Aug 27, 2011 | Dell OptiPlex GX260 PC Desktop
Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Orange power switch light Dell Gx260
Gx260-Gx280 have a known issue with the motherboard capaciators. Take a look at the capaciators on the motherboard and check if any look like they have bludges at the top particularly around the memory banks. If any of them look like this the motherboard most likely needs to be replaced.
Dec 29, 2008 | Dell OptiPlex GX260 PC Desktop
Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Dec 15, 2008 | Dell OptiPlex GX260 PC Desktop
Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Sep 24, 2008 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 won't boot
i think that your ram may have broken. ram is the stuff which is commonlyknown as memory and makes everything run. i had the same problem with mine and replaced the ram. it then worked fine.
should work
matt
Aug 14, 2008 | Dell OptiPlex GX260 PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Gx260 pc wont start
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Aug 16, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
