Question about Canon LASER SHOT LBP-2900 Printer
My printer seem to get paper jam after less than 10 print. How to fix this? I remove the paper and the problem seem to repeat? Is there a need to reset my printer toner? if not what other solution can you offer to fix the problem?
  • 1,219 Answers
Hi, where does paper gets jamed? In fuser assy, in pick up assy,...?
First:
If the paper comes out ( from the fixing assy ) bent in the roll that means that the paper is to moisturized.Open fresh pack of paper and try again.Or flip existing paper upside down as firs aid.
Second: open the toner cover and remove toner crg.,than you will se pick up roller which you need to clean by alcohol by means of piece of fabric and dry it out.
Hope that helps!
Posted on Sep 06, 2010
Testimonial: "Thanks, You are an expert indeed. I did loosen the paper and so that is the not problem. I think is the roller problem "
  • auto er Sep 07, 2010
    Sometimes the pick up rollers will get slick, cleaning with rubbing alcohol and a q-tip will mostly do the trick but if the rollers are worn the should be replaced.
    Also (fanning the paper) like thumbing thru a book will also help in the pick-up process.
  • Canon tech CROATIA
    Canon tech CROATIA Sep 07, 2010
    I agree also with auto er, but You also can with tweezers pull the rubber in one side to "relocate" the worn part, doing that the OK part of the rubber will now do the pick up and you do not need to change roller.
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
My printer has a paper jam, however when i take out and replace the paper , it continues to jam. There is nothing in the printer that could be stopping the printing process, im unsure of how to fix this...
Posted earlier to you but to repeat.
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Jun 14, 2011 | Epson Stylus CX6900F All-In-One InkJet...
When we hit the print button to print a page the paper will not feed into the body of the printer and the sign flashes for us to remove jammed paper and hit start button, when we do this it just keeps...
Paper jams
85% of paper jams are caused by worn rollers Chances are, when your tech arrives, he'll tell you that the jams were caused by worn feed rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
MP150 reset:
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Canon MP830 will not print Error code 5C10, And 5100 donaldbetty@juno.com
5C10 seems to indicate a paper jam. 5100 indicates either a paper jam or ink tanks not seated properly.
A) Paper jam: There is a rear cover on this model. Many paper jams cannot be seen from the outside. Sometimes even a scrap of paper from a previous jam will disrupt the paper path.
B) Follow your manual for installation of the ink tanks. Remove and replace the ink tanks carefully following the instructions.
C) Should these remedies not fix the problem, you can try resetting the device:
1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) If solution fails, your MP 830 may require repair
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer repeatedly jams.
there would be little bits of paper jamed inside the printer, now wnen ever you tries to take a new print at that time the bits of paper blocks to come out..........just open the printer and clear off the papers
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Paper jam notification after printing one page, no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Canon LASER SHOT LBP-2900 Printer Logo
266 people viewed this question
old marine
old marine
