Question about Epson Office Equipment & Supplies
My Epson Stylus DX4050 printer was showing all ink cartridges as empty in the print box when requesting to print. I haven't used the printer much and though I knew the black was getting low I thought the coloured cartridges may have dried up. I purchased some DX4050 ink cartridges on the internet (not Epson!) and have installed them but still have the same problem. Any ideas?
BinaryCode
  • 54 Answers
SOURCE: Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Posted on Jun 12, 2008
cinek79
  • 320 Answers
SOURCE: won't print with one empty colour cartridge
hi you need replace empty cartridge atherise you can`t print, most epson`s printer works like that.
regards
Posted on Oct 28, 2008
  • 126 Answers
SOURCE: Epson Stylus Color 1160
Hello Stompson,
You can go here and download this utility. It will allow you to select your printer model so you can reset the maintenace request.
http://inkjetprinterhelp.us/epsonSSC.html
If in the event this does not work try this 2nd procedure, it normally works with the older Epson models and may work for your model too.
1. turn off the machine for at least 5 minutes and disconnect the interface cable to the computer
2. push and hold down the "ink" button and the "paper" button and turn the printer on.
3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.
Posted on Nov 09, 2008
tigertail
  • 163 Answers
SOURCE: service manual for epson stylus dx4000 series
You could try here:
http://www.2manuals.com/product_reviews_info.php?products_id=792&reviews_id=150
Posted on Mar 16, 2009
tigertail
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
Can i print documents using black ink only when other inks are empty?
All the ink cartridges need to have ink in them to allow you to print, even if you only want to print in black only.
Oct 14, 2012 | Epson Stylus CX8300 Printer
Trying to print n a epson printer without black ink carthiage
Unfortunately the Epson stylus needs both ink cartridges to print. I've tried useing an emty cartidge to "fool" the printer,but that won't work. When my Epson was ready for replacement I bought a printer (Lexmark) that prints with one cartridge empty.
Dec 27, 2010 | Epson Stylus C46 InkJet Printer
How can I remove from my stylus sx115 the ink
Found this on the web. You can download the entire
manual if you like. If you find this helpful, pls rate me.
ftp://download.epson-europe.com/pub/download/3233/epson323393eu.pdf
Mar 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX3900 says all cartridges empty but not true
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
How to change cartridges epson stylus sx 400
From older Epsons: If the ink cartridges are empty (red light on), hold the ink switch 3 seconds to move the print head to the left. If they are not empty, hold paper switch until print head moves left. Once you remove a cartridge you can't reuse it, even if there's ink in it according to Epson.
Nov 16, 2009 | Epson Stylus C86 InkJet Printer
Epson stylus dx4050
hello, I hav Epson Stylus Dx4050, there is black ink,but the colours finished and it stopped printing, so please if you could tell me if the 4 colours must be there to print or what can I do?
Thanks very much
Jul 01, 2008 | Office Equipment & Supplies
Problem with Epson dx4050 ink replacement
If you still have this problem would you post a new comment here, and I promise I will help you solve this. Otherwise let's called it solved shall we?
Jun 27, 2008 | Epson Stylus C60 InkJet Printer
Epson stylus C64 ink jet printer
if you have installed the software for the printer correctly it will show you the approximate level of ink every time you prints.
Jun 18, 2008 | Epson Stylus C64 InkJet Printer
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
