I have a Canon Video camera ZR 90A. When in Video recording mode, everything is black through the visor or on the LCD display. It looks like only the sound is being recorded. Could it be the CCD that is broken?
Does the screen play back the pictures ok but not during record mode? Or is it off all the time and you used a computer to review the shots that were taken?
Check the basics listed below:
1. The screen may be switched off. Press the display button on the back while the camera is on.
This toggles the display setting between various settings such as
Off/ On / Info. Keep pressing the button to try the aternate modes, it just goes round and round to 2 -3 different modes.
2, Check that the monitor brightness setting is set to medium at least
in the menu's.
3. If the problem is only affecting recording then check that
the main record settings are correct for the type of scene you are taking. For
example don't use Beach, Snow, Candle or manual with a high shutter speed while taking regular daylight shots with minimal lighting.
. 4. If the LCD display has a hardware issue you could connect the camera
to a TV using the video output jack and look at it that way. Then
you'll know if the built-in LCD is ok or not.
5. Having a
damaged or stuck video output jack COULD cause this problem also since
that circuitry is designed to automatically shut off the built-in LCD
display when you connect a video cord to it. Note that having a video cable plugged
in to the video output jack would shut off the display also. Such as when you have it connected to a TV.
I
have found several other people with the same problem Canon ZR60 won't
record ,only get a black screen ,only a few years old with less than 75
hours use .Can this be fixed free from Canon .
The CCD Image Sensor is defective. I have one just like it. The CCD is the chip at the other end of the camera lens that "sees" the image. This model uses a CCD manufactured by Sony that is used in Sony models such as DCR-TRV250 and CCD-TRV138. Canon also uses this Sony CCD int their mini-dv models such as the ZR-60 and other ZR series models. Sony and Canon readily "own up" to this and if you go on their websites you will see that they will fix them for free. They even pay the postage both ways. We were on the phone today with Samsung and they deny any knowledge of the problem and want $150 for repair if I mail it to them. They also will sell me the part for $103! I wish you luck but it might take a class action suit to get them to do anything. I'd love to hear what Samsung tells you... Mike
