Any type of external speakers . I will attempt to add a remote amplifier between the two products (TV and speakers) I get very bad volumne control at the high end right now with way too much bass.
    President:
  • 1,851 Answers
You don't mention if your speakers are active or pasive. In case of active speakers (if the need power supply they already have included amplifier) you can't connect them at your amplifier's output.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 06, 2010
I want to connect external speakers to tv
If this unit has audio output jacks then these would be connected through an amplifier to provide your external speakers. Caution: Do not open the tv and connect additional speakers to installed speakers because you'll blow the small audio amp in the tv. I have seen this attempted many times
Dec 24, 2013 | Philips Magnavox 27MS343S 27" TV
Remote sends tv crazy
The volume controller may have been damaged from a power surge or internal disturbance; not related to the a remote control. Your TV has a set of External Out connections, usually RCA jacks colored RED White and/or Black. Red and White jacks are relative to Right and Left Speakers when an attached cord with RCA male connectors are used and connected to an Amp or some type of receiver. You should be able to use the TV OUT Audio to a small Amplifier and connect to a set of inexpensive speakers or any external speaker set. This method bypasses the TV's Internal speaker system as an alternative measure.
Dec 23, 2013 | LG 42" 5700 Series LED HDTV - 42LN5700
Tv volumn
Are you using another remote for the guide? Like the cable box remote? If that is the case then the remote could be sending a signal to the cable box that is the same as the signal used to adjust the volume on the television.
Apr 30, 2013 | Boston Acoustics TVee Model Two TV...
The sound is gone
it will depend if the problem is only the speaker of the tv itself is bad, you can hooked up external to the headphone jack.but if the problem is with in the amplifier circuit you must trouble shot the circuit first.might the amplifier ic get bad.
Oct 10, 2012 | Televison & Video
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
How to add more Sound, to my Sharp TV , even in the background, when watching movies, sound is very low , think its dew to cable service? Or would just like to Add external Rear Speakers?
The easiest would be installing a surround sound or other sound system that will amplify the audio. Also, some cable boxes actually have a volume control that is only found on the remote, try turning this up.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My sansung remote control 2 dvd at the same time...how to have only one remote for each
When attempting to increase the volumn on the television either using the remote of turning the reciever knob by hand the volumn increases dramatically. I am concerned the speakers might blow. Does anyone know how what the problem might be.
Jul 05, 2009 | Onkyo TX-SR705 Receiver
How do I hokk up external speakers to the Sharp
I want to hook up external speakers to my new lcd hdtv Sharp and control the audio with my remote.
Mar 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Computers & Internet Logo
David Payne
David Payne
