Question about Sanyo VPCE1090 Digital Camera
My camera dispays lens error 0x0211 - Sanyo VPCE1090 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 06, 2010
  • barthman Feb 23, 2011
    I suggest to read and check this FIX at this website before doing anything on your camera.
    http://artsybelle.blogspot.com/2011/02/s...
    Hope this helps!!
How do i fix my lens error 0x0211?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 13, 2011 | Sanyo C5 Digital Camera
Lens error, len goes in and out about 3 time before the lens error screen dispay comes on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Mar 02, 2011 | Nikon COOLPIX S200 Digital Camera
Okay so i turned camera on it said lens error 0x0211 i have a pentax optio
Did you drop the camera? You can try taking out the battery and trying again, but this is something most people see after some shock to the camera and usually needs repair (but the cost is often close to the cost of the camera).
Sadly, the owner's manual doesn't say anything about lens errors, but as often as they occur, it should!
Feb 27, 2011 | Cameras
I turn on the camera and it saysprogram green mode for a while and then it shuts down saying lens error 0x02110000 although im not sure how many 0's there are on the end of the 0x0211
Dear Sir,
This is problem of the lens block.You are not able to solve this issue by your self.You must send thi camera into the local Pentax Service.
Best Regards
AIOS
Apr 18, 2010 | Pentax Optio E60 Digital Camera
Sanyo camera vpc-s1275 lens error 0x0211
i there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Apr 07, 2010 | Cameras
Lens error 0x0211??? help pls
Hello
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Apr 01, 2010 | Sanyo Vpc-s1070w Digital Camera
Lense error :0x0211
When i turn on my camera presents Lens error 0x0211 and lens will not go back in, camera will not turn on, keep getting that message
Dec 19, 2009 | Sanyo Cameras
Dispays LENS ERROR
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 20, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens error 0x0210
Pentax optio E75 lens error 0x0211 l'objectif ne rentre plus
Aug 16, 2008 | Cameras
Sanyo VPCE1090 Digital Camera Logo
156 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
