Question about Samsung Televison & Video
I have a Samsung LN-S325D, never had a problem with it before. I like the picture settings set to Movie with the color temp on normal, but now every time I switch on the TV the pictures settings re-set to Dynamic, and after about 20 minutes of watching it, will re-set to Dynamic. Is there any way to fix this?
HDTV GURU
  • 261 Answers
SOURCE: Samsung LCD Question
possibly take a picture with cell phone then send it. That may work better. Jay
Posted on Feb 18, 2008
SOURCE: samsungLE26 R8 Picture Settings Problems
tv had reverted in to shop mode.I accessed the secret bmenu and restored the normal settings. Thanks
Posted on Apr 08, 2008
  • 21 Answers
SOURCE: Hi, I have new Samsung
if it's still in warranty, call 1-800-samsung and report it, other wise you need a main board or there could be a firmware upgrade on samsung web site that could fix it
Posted on Dec 28, 2008
jscruggs420
  • 36 Answers
SOURCE: Lost picture all color lines are at top of screen
Thats what happened your convergence went out, those parts can be found online for as little as 12.50 a piece. If you are good with solder its an easy fix. I found a guy on craigslist in denver who fixed it for 150
good luck
Posted on Feb 11, 2009
  • 4 Answers
SOURCE: Adjusting to the proper color
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
Posted on Feb 18, 2009
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
LN-T1953H picture settings
It all depends on where the set is located. Try looking in the manual. Samsung has them online for free.
Jul 01, 2008 | Samsung LN-T1953H 19 in. LCD HDTV
Ideal settings for Samsung LN-T 4234H
sure, lcd tvs need to be tweeked depending on the light in the room the darker the worse the picture. so try this
from standard:
picture: 85 to 95 %
brightness: 45% or adjust the black of the video to the black of the pilar bars to equilize them.
color: 32 to 38% or until the flesh tones are not so hot
sharpness: low 10%
tint: always to center
color temp: cool1
back lamp ( if avalible) low when lights are dim, high when lights are bright.
the problem with LCD is they don't look so good with dark sceens. the contast ratio is very low. natively 3000:1 aas compaired to plasma or other direct view TVs. the LCD is back lite and the thin materal of the LCD can not completely block the back light from coming thru. there for the complete "black screen" is illuminated "blue". the best thing is to keep the lights on bright in the room for the best picture.
Feb 22, 2008 | Samsung LNT3242H Television
Setting
GO UNDER MENU UNDER PICTURE SET TO DAYTIME MODE
Jan 18, 2008 | Samsung LN-T4042H 40 in. LCD HDTV
Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Nov 13, 2007 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung lcd tv le32r8 (Picture - Movie setting)
The TV is probably in Shop mode, when your TV is initially turned on you can choose between Shop mode or Home Mode.
In Shop mode the TV automaticly returns to the standard setting after a while, they do this so customers can "play" with it.
Press down de Volume button and then hold down the Menu button for five seconds on the side panel of the tv.
Oct 25, 2007 | Samsung LN-R409D 40 in. LCD Television
Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
Oct 05, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Televison & Video Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
