Question about Dell Vostro 1014 Laptop Computer
Bluetooth device not detected in device manager and not even in bios. bluetooth device shown none in bios. what can be done to solve the problem.
  • Dell Master
  • 629 Answers
If the bluetooth device is not detected in the BIOS, chances are, your laptop did not ship with a bluetooth device. Try to go to support.dell.com and check the original system configuration to verify if your system indeed came with a bluetooth card. you can also check with dell support about it. if you have verified the card is available and it is enabled in the BIOS, try to remove and reconnect the card and if it is still not detected, you may have to get a new bluetooth card or request for warranty service/replacement if applicable.
Posted on Sep 06, 2010
Bt211 not detecting devices
kindly check your hardware its working on not check by hardware detaction tools downlode by google ,& check hardware name .& driver version .
Aug 30, 2017 | ASUS USB-BT211 Mini Bluetooth Dongle -...
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
Wireless not found
You should check the BIOS. Although it is extremely unlikely that the BIOS has it disabled. Verify that whether you have a wireless card installed from there. If so some new laptops have a switch which disables the wireless card. This can be usually be found on front or sides. You could also check device manager and make sure the NIC is enabled. To get the device manager Start -> Run Type devmgmt.msc and hit enter. Expand and check for X or ! with red / yellow color for each (if on a failure that will be shown)
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem... Thanks for contacting Fixya
May 30, 2010 | IBM ThinkPad R52 Notebook
HOW DO YOU TURN BLUETOOTH ON
Check the BIOS to ensure the wireless card is detected. Also verify the Wireless setting is turned on and not set to Always Off.
If the Bluetooth device is installed, also verify the radio LED is enabled. You can turn the wireless and Bluetooth cards on or off with the wireless switch.
If the card does not show up in the BIOS or Device Manager, try reseating the card.
Oct 06, 2009 | Dell Inspiron 1525 Notebook
Laptop bluetooth not found
Hi
1 > Please check for the product specification whether does notbook has integrated bluetooth Device
2 > Load the Bios Default setting by entering into the BIOS
Steps are
> As soon as on the notebook keep tap on the F10 button
> Press F9 to load the BIOS Defaults
> Press F10 to save and Exit from the BIOS
3> Check for the Wifi Button on/off status
4> In Device manager check for the Bluetooth Device
5> Check in the safe mode for the Bluetooth Hardware in the Device manager.
select Mycomputer-Right click select Manage - Device manager - Bluetooth
To access the safe mode steps are
Restart the system Keep tap on F8 key
In Advanced startup option Select the Safe mode with Net working
Regards
anand_manj2005@hotmail.com
Apr 12, 2009 | HP Pavilion dv6000z Notebook
WLAN not being detected in HP Pavilion tx1210 laptop
first of all is the wireless adaptor recognized under the device manager?
no, you need a new mini pci wireless lan card
yes, the wrong driver is installed, the windows utility is not enabled
Mar 02, 2009 | HP Pavilion tx1000z Notebook
Sony VAIO FE690P Bluetooth device doesn't work.
Before doing anything whit the bios, try this if you havent alredy
Turn on the wireswitch in the front of your laptop
Double-click on LAN/B icon on the taskbar to display the wireless device switch window
Select the eneble bluetooth device option
Click OK and try if it works.
Yuo dont see the B in your taskbar cos it isent activate
Good luck to you
BTW, if you vae installed diferent drivers, i sugest you uninstall them and install back the original ones
Dec 11, 2008 | Computers & Internet
WinXP SP2 not detecting bluetooth device
you have to install windows vista again only to enjoy the full function for the notebook coz in windows xp it won't work i to tried this and had faced the same problem in acer travelmate laptop
Apr 22, 2008 | HP Pavilion dv4000 Notebook
Cant find my wireless card in device manager in acer travel mate 2300
In some Acer models, there is a software switch in Start/All Programs/Acer Launch Manager. If this is missing, you need to reinstall since even with the WiFi hard switch activated, this application is required. This is so especially if a new/clean/OEM install of the OS has been done on the laptop.
In some models, there is a hard switch either at the front or at the side to activate the internal wifi (and bluetooth). Still in other, there is button on the leading edge of the computer which also serves as an indicator lamp,
Some models also have WiFI enable/disable in the BIOS/CMOS setup.
Still others have a button along with the Easy-launch strip (top) together with the those for email , bluetooth , Acer Arcade & others.
As shown above, depending on the specific model/region version of your laptop, the WifI activation can be varied.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 19, 2008 | Acer TravelMate 2300 Notebook
go here http://support.acer-euro.com/drivers/notebook/tm_5620.html
in top window choose bluetooth_5.0.1.1500
download file and save to desktop
then run it
Hopfully that will work for you
Nov 14, 2007 | Computers & Internet
Dell Vostro 1014 Laptop Computer Logo
326 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
