Question about GPS
Ford Fiesta Zetec Recently i turned off BT using menu option but now can't turn it back on. All the menu options indicate Bluetooth being on however there is no icon indicating it is working. Once a phone has been Debonded how do you rebond it? All settings on the iPhone have been reset to try to resolve problem but still no Bluetooth connection. User Manual only seems to cover initial connection. The phone is appearing in the list but connection is failing.
SOURCE: Bluetooth Connection issues
i have also had this problem, i have found that if i get the person to send me something first, there name will appear on the list of bluetooth list, when trying to send them something all you then have to do is click on there bluetooth name and it tends to connect. hope this helps.
Posted on Jan 08, 2007
  • 217 Answers
SOURCE: Menu Options
sound or volume can be lowered or turned off using zoom control button
Posted on Aug 31, 2007
SOURCE: Bluetooth connection not working Kenwood KCA BT100 with KDC W7537U and a Nokia N95
Seen a site called which does all good price on memory cards
Posted on Dec 10, 2007
  • 13433 Answers
Try asking someone else, have you tried updateing the firmware on the gps?
Posted on Jul 17, 2008
SOURCE: My Guide 3000 GPS System
it's the same menu but the pna thinks the sd isn't in, so it hides those buttons. u should get to sd card to your computer and look at addons.txt. that contains information about the menus, and if that looks alright(
Games = "icons/games.bmp", "", 0
Navigate = "", "\\Flash Disk\\myguide\\myguide.exe"), then u should go to windows explorer. when it boots, after u hear the noise, notice a black square appearing in the left corner, "click" and hold until u see the a menu close to that when u right click your computer's desktop(if it's windows). click new folder and keep touching the desktop for the next ten seconds, so the "main menu" won't appear. then enter the new folder and windows explorer will launch, click the address bar and erase what's there and type \ then press enter. it will go to my computer. go to flash disk (which is the internal rom) and click igo launch. that should launch the navigation software.
Posted on Jul 25, 2008
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at or going to
Mar 01, 2014 | Digix BT-100 Portable Bluetooth Wireless...
How do i turn my bluetooth on and reieve songs
Turn Bluetooth ON or OFF on BB RIM:
1. From the Home screen, press Menu.
2. Click Options.
3. Click Bluetooth.
4. Press the Menu key.
5. Click Options.
6. Set LED Connection Indicator to On or Off.
7. Press Menu.
8. Click Save.
Using the other phone, or other device, search for the available Bluetooth device in range. The BB should be detected or found. Then, pair the two devices and connect. Once the two devices are connected, select a song from the source device, and find the option to send the song via Bluetooth.
Thank you!
Sep 11, 2010 | RIM BlackBerry Storm 9530 Smartphone
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
Accelerates on own
I would have them check to see if a minor clutch adjustment may remove the 1-2 grate. You might ask it the is a shift linkage lubricant to smooth out the shift as well.
Jul 15, 2009 | 2008 Ford Focus
Strange symbol appeared, battery life now much shorter
Yes! That's definately your bluetooth indicator. Btw, there should be an icon glossary. try setting and tools/phone info/icon glossary. As far as the BT indicator check your bluetooth menu and disable it, assuming you have no BT peripherals as evidenced by your lack of understanding regarding the BT icon and effects of peripheral hardware on battery life.
You may also wish to do a little research on crop circles. But try not to get too weirded out.
Apr 15, 2009 | LG enV VX9900 Cellular Phone
You should take it into a Ford Dealership. They can help you use it.
Mar 06, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Ford Focus Zetec 57 plate
Go back to the dealer and demand the manual.
Jun 23, 2008 | 2007 Ford Focus (3 Door) Hatchback
Plantronics bluetooth headset 610
Hi. First the code. Almost every headset uses the code 0000 (that's 4 zeros).
Now the pairing. You didn't say which phone you are using. I'll assume you know how to get into "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your phone.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth.
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your phone.
Again open "Options"
Open the Bluetooth menu.
Click on "Add Device".
Your phone will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your phone.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Mar 30, 2008 | Plantronics Bluetooth Headset 610 Wireless...
GPS Logo
129 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
