Question about Jensen JHT525 System
Hey i have a Linkman home theater system and it is making a very loud buzzing sound and when i torn it the volume to 0 it stops but when its just a little higher volume like 1 its there again. I have changed all the input sections unplugged everything except for 1 speaker and the power cord of cause and is still making the sound. plzs i need help with this its driving me insane
2 Suggested Answers
SOURCE: Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Posted on Oct 02, 2008
What causes the sound to be distorted all the time,in every mode?
The main IC is damaged. If you can replace this IC then go for it, if not seek the professional assistance of a Technician in your area. This particular home theater system came from the manufacturer with that defect, a cheap Chinese made RCA. These Chinese made electronics are not made to function properly or last a reasonably long time...
Jun 19, 2014 | RCA RTD317W Theater System
How do I get the code for a Linkman LM2216D home theatre system
If you have a new universal remote and it has a code search feature, you can search for a code that will operate your Linkman system. Your description is backwards. The code library is in the remote.
Nov 28, 2012 | Audio Players & Recorders
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
My child messed with the settings on my 321 bose
Reset all EQ settings to 0 for a starter. It sounds as if it is EQ'd down all the way.
Jul 05, 2009 | Bose 321GS Series II System
Volume Control on my SCBT100 Blu-ray Home Theatre doesn't work.
Unplug the power and let it sit. Plug it back in and it should fix. Worked for me.
Oct 12, 2008 | Panasonic Home Theater System System
A loud buzz sound when the surround sound unit is powered on.
There is most likely a voltage regulation fault, or some filter capacitors that are going defective. It would be best to have this serviced before the parts fail completely and cause some damage.
Jerry G.
Jun 03, 2008 | Audio Players & Recorders
Sound Problem
the amplifier must have an individual speaker volume controller that allows you to set different volume levels for each speaker independently, find it and set new levels.
Apr 29, 2007 | Pioneer HTP-2800 System
Jensen JHT525 System Logo
103 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
