Question about Xerox Office Equipment & Supplies
Not able to get prints, the printer is showing ISU error
  • 567 Answers
The error would be stating LSU. It stands for Laser Scanning Unit.
The LSU error signifies that there is an issue with the laser scanner, the part that helps making prints.
There could be an issue with the laser or perhaps the polygon mirror, maybe the sensor or a combination of these that needs to be fixed.
In the User's manual it is stated:
To turn off power and wait for 20 seconds. Then turn on the power again.
If the problem is still there then you will need to call for service.
The service tech will recommend a new laser unit or control board.
Best of luck!
Posted on Sep 06, 2010
How to fix C3100 Scanner carriage problem ?
Hi.
C3100: ISU home position error
It usually means the scan carriage can't move.
If it s a little MFP, you can unlock the scan with the yellow button on the left of the glass (under the DP). (This was only meant for transport reason).
Otherwise - Possible cause:
Defective FFC between CCD PWB (YC1) and control PWB (YC8).
- Replace the image scanner unit (ISU)
Defective FFC between control PWB (YC6) and scanner PWB (YC103), or improper FFC insertion:
- Reinsert the FFC. Also check for continuity within the FFC.
If none, remedy or replace the FFC.
Defective home position sensor.
- Replace the home position sensor.
Defective harness between ISU motor and scanner PWB (YC104),
or improper connector insertion.
- Reinsert the connector. Also check for continuity within the connector harness. If none, remedy or replace the harness.
Defective ISU motor.
-Replace the ISU motor.
Mar 16, 2016 | Kyocera Office Equipment & Supplies
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
How to reset error code 3100 on Kyocera FSC8520MFP
Code 3100 Description ISU home position error
ON/OFF of the HP sensor doesn't change by retrying, after a prescribed pulse passes from power supply ON. Causes Defective connector cable or poor contact in the connector. Defective home position sensor. Defective ISU motor. Defective CCD PWB. Defective engine PWB.
Feb 14, 2015 | Kyocera Office Equipment & Supplies
ERROR 3100
The home position is not correct when the power is turned on or at the start of copying using the table.
check the movement of the scanner carriage. make sue the lock is not on.
Aug 12, 2014 | Kyocera FS-3640 Printer, Scanner, Fax...
Error 3100 in kyocera fs1030 mfp
ISU home position error. Check the scanner lock to make sure it is not engaged. If not it could be the home position sensor for the image scanner unit.
Dec 17, 2013 | Kyocera FS-1030MFP Mono Multifunction...
Isu error shown by printer
Hi
problem is your laser scanner unit.
you have to replace new LSU Unit.
calling for service is suitable.
Aug 29, 2012 | Samsung SCX-4300 All-In-One Laser Printer
Can't uninstall winfax pro 10.0. Says wfxunist.isu may be
Follow their instructions for manual removing:
http://service1.symantec.com/support/faxprod.nsf/docid/1998102114161204
May 22, 2009 | Symantec WinFax Pro for PC
Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Feb 27, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
137 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
