Question about iPhone Apps
I heared of SplashShopper / Zenbe Lists software..what is it exactly?
  • 1,141 Answers
This software is a great travelling application.I've created a robust packing list so I never have to think about what I need to pack. Makes packing more efficient and gives me more personal time and peace of mind to know I didn't forget anything.
Posted on Sep 06, 2010
WHAT MEAN SYNONYMS
The definition is "another word with the same meaning". So synonyms can be exact or just close in meaning.
Lists of synonyms are obtained from a Thesaurus. Roget's is the most well known one. Online, go to
http://www.thesaurus.com/
Sep 12, 2014 | Computers & Internet
Toshiba c655 xp driver
Toshiba lists exactly 170 different C655 Satellite laptop models.
Find your exact Satellite C655 model number then check Toshiba downloads and support at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Dec 16, 2011 | Toshiba Satellite Computers & Internet
Refrig Model # FRS26ZRG Ice maker is connected to a reverse osmosis. Has 60 lbs. psi. Was working fine now i hear the switch it sounds the same only no water comes into trays. also no water at door but it...
1. Check the water line to be sure it's clear, unobstructed and that water is available (check your RO unit too)
2. Check the water filter
3. Check the water valve
Visit this site for more info and diagrams - www.appliancepartspros.com
Put in your fridge's exact model and examine the parts lists.
Aug 21, 2010 | Frigidaire Refrigerators
Running with 2 monitors on a Windows 7 OS.. 2 exact brands / size. main monitor shows the correct driver. 2nd Monitor shows Generic PnP Monitor. How do I get 2nd to show the correct monitor? I tried...
You will need to go into Device Manager, and look at your Monitors listed. One probably lists as Acer AL2016W, the other one lists as Generic PnP Monitor. To fix this, open the Generic PNP Monitor (right click and go to properties). Then choose "Update Driver" button, Select "Browse my computer for driver software", then select "Let me pick from a list of device drivers on my computer".
You should automatically get a list for the Acer AL2016W option. Depending on how it's cabled up and connected, you ay either get Analog, Digital or DisplayPort (or HDMI if that model allows it). Choose the option that's relevant. Now your monitors should list properly.
Nov 30, 2017 | Acer AL2016W 20" LCD Monitor
Problem with PCM Navigation
Hi I have a 2006 Caymans S and have exactly the same problem, everything works except the Sat Nav!
In the navigation option menu, it lists 0 satellites being picked up
The dealer looked at it today and replaced the GPS antenna, but didnt fix it. They too mentioned about a new unit...
I will post if I solve it, but if you find out what is wrong I would really like to hear about it.
Dec 15, 2009 | 2003 Porsche 911 Carrera
Message saying 900 Service RIP Software.
This typically indicates a controller board failure. I would need to know the exact printer
model to tell you what part you would need order.
Example: T632N model uses part number
56P3083 -- CARD SYSTEM NETWORK T632N
You can look up various printer models and parts lists here at fastprinters.com
Jul 22, 2009 | Lexmark T522 Laser Printer
I dont have my software key to download xitel inport
In order to help you, i'll need to know EXACTLY what it is you need to software key for!
If i hear what it is, i'll do all i can to help.
Sorry I Couldn't Help More
Feb 01, 2009 | Xitel INport (HFLI1X1) Audio Input
I want verify the data drop town list and its formulas
Hi Manjee,
There is no formula used in data dropdown list, so it can not be verified as a formula using evaluate formula, trace errors, trace dependents, trace precedents etc.
If you want to create such lists simply:-
  • Select input range then goto
    data --> validation --> allow, list --> select the list range
  • To veryfy you can follow the same process
    data --> validation --> allow, list ,
    now you can see the exact range from where the data is picked.
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 19, 2009 | Microsoft Office Excel 2003 for PC
Quickbooks
You can import external lists, and some transactions, but only from an exel spreadsheet, and then, only if you use the IIF format Intuit has laid out.
If you go the help section of QuickBooks, and search on Import, it will give examples. I will tell you straight up, it can be a pain!!!
f you choose to use the IIF format, it is IMPERATIVE that you follow the header setups EXACTLY, including punctuation, and yes, they are case sensitive.
Jul 14, 2008 | Intuit QuickBooks: Pro 2005 for PC
Block both incoming and outgoing cal to a particular mobile number.
Handy Blacklist protects your time and peace of mind by keeping undesired calls off your phone. If there is someone you just don’t want to hear from, let Handy Blacklist keep that person off your phone!
2 types of lists with different functions will keep unwanted calls hidden from your eyes. You have one blacklist and one or several Allow lists. Only one list can be activated at the moment.
Blacklist contains numbers you want to be blocked. You can add numbers from recent calls, contact list or just by typing them. If you reject a call manually, the software will propose you to add that number to blacklist automatically! Blocking of Private and Unknown calls is also available.
Allow list contains numbers which will be allowed to receive while others will be rejected. In addition, you can choose a "reject" action to return a prewritten text message back to the caller. A notification of the missed calls appearing in a popup note can be set by user as well.
Jun 04, 2008 | Nokia N70 Cellular Phone
iPhone Apps Logo
705 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
