Question about Acer Aspire 5315 Notebook
How can I clear the setup password, and where do I find the point to short to clear it.
  • 393 Answers
Open the ram cover remove ram also remove sticker u can find there it's very small just short jumper for 15 second with flast screw driver .. if same its mean password store in bios... u need to update bios with programmer.if u need bios file bin or rom i have u can contact me @ sim4182@yahoo.com Thanks
Posted on Sep 14, 2010
Dell Inspiron N5040 with APTIO BIOS version A03, Service Tag BGS2GR1, ESC 24959208781. The APTIO setup utility is locked and the password is unknown, with the boot device set to Network PXE boot and is not...
I can't find a decent manual for your computer but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
Jan 11, 2014 | Dell Inspiron N5040 Black New
How do I remove setup password ?
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.If the password is not cleared you will have to short the jumper on the motherboard to clear the password. Some systems make it easy by just having to remove a pin that connects two points on the board. The Password Jumper should be labeled on motherboard.
Apr 03, 2012 | Dell Latitude E6410 Notebook
My acer 2490 is asking for a setup password and i dont know what this is i cant get on my computor at all it start of black screen then says writing then tells me to press f2 and when i do i get a light...
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Dec 21, 2010 | Acer TravelMate® 2480-2698 PC Notebook
I have an acer laptop 2920 i lost the password which has locked
There is only one way to clear cmos (BIOS) passwords and I'll show you the procedure.....
Steps for Clearing BIOS Password Check
If users set BIOS Password ( Supervisor Password and/or User Password ) for a security reason, BIOS will
ask the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
q Power Off a system, and remove HDD, AC and Battery from the machine.
q Open the back cover of the machine, and find out the HW Gap on M/B as picture.
q Use an electric conductivity tool to short the two points of the HW Gap.
q Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
q Restart system. Press F2 key to enter BIOS Setup menu.
q If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password ( Supervisor Password and User Password ).
Below is the picture showing the location of the jumper next to the memory module slots. This is the jumper connections that have to be "shorted".
Jan 28, 2010 | Acer Aspire 4720 Notebook
Acer aspire 2920 forgot my acer security password
following steps:
try again.
Below is the picture of the Jumper location by the memory modules. These two points have to be "shorted".
Could you please guide me how to remove bois possword for travel mate5730g
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
Check below for the picture of the HW Password reser gap. The gap that needs to be "shorted" is G77.
Jan 27, 2010 | Acer TravelMate 5730-6204 Notebook
My acer aspire one crashed and i need help
Below are the steps for the resetting of the password. Below the steps is the link for the service manual. On page 113 is the picture of the jumper pads that need to be "shorted" to reset the cmos.
following steps:
try again.
http://tim.id.au/laptops/acer/aspire%20one.pdf
Dec 26, 2009 | Acer Aspire One PC Notebook
ACER ASPIRE 4730Z. How do I clear the CMOS (password)?
Below is the steps for clearing the password. Below that is the link for the manual, the picture of the jumper tabs is on pg. 153, good luck
following steps:
try again.
http://tim.id.au/laptops/acer/aspire%204730z%204730zg%204330.pdf
Oct 11, 2009 | Computers & Internet
Gateway Laptop - HDD Password locks me out! Help
if the hard drive has a locked password on it, you cannot remove it unless you have the password. you might try using some SMART disk utilities, but in my experience, it has no worked. Some hard drives have a list of reset passwords, but I have never had success in getting these to work.
try downloading Hiren's boot cd. (gogle search it) it has many utilities for hard drives on it. iyt may have something to help.
alternatively, buy a broken identical model on ebay and swap the PC board. make sure to have the same hardware revision level and model.
Sep 10, 2009 | Gateway MT6707 Notebook PC
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
