Question about HP Officejet 4315v All-In-One InkJet Printer
It is a printer, fax, scanner, and copier and right now it is stuck on the fax setting. I can't get it to switch to print anything??
  • HP Master
  • 17,129 Answers
Remove off power and keep aside. If there seems to be a conflict with the PC then reinstall the printer sofftware.
Connect the printer back after few hours to ensure if this has reset.
If not if there is no action with the customere control there seems to be possible errrors in the microprocessor controller board.
Try to remove and tighten all connections... or a possible board error.
Hope this helps
Posted on Sep 06, 2010
Working offline. Printer will not print from word or excel.
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
OR:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it's set to print online
Feb 07, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
I have HP 1200 psc I have a document that will not delete therefore I cannot print anything at all I have tried switching off everything - no luck - can you help?
From Printers and Faxes window
1. Right click the printer icon for your HP 1200 PSC then select "Set Printer Offline".
2. Right click again the printer icon then select "Cancel All" print jobs.
3. Once it's cleared, right click the printer icon again and then "Set Printer Online".
Or, restart the computer and the printer.
Oct 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
The printer does not respond to print order. I get a message saying camera is connected, it is not.
The Camera Detected message is your PC detecting the scanner on the Printer - What happens when you try and print?
Also, try the following:
Remove the printer USB cable from your PC -> Restart your PC -> Log back onto your Profile -> Click on Start -> Control Panel -> Printers & Faxes -> Delete all printer entries -> Restart your PC -> Log back onto your profile -> Plug the printer USB cable into the back of your PC -> Go into Printers & Faxes -> Right Click on the Kodak 5100 AiO entry -> click "Set as Default" -> Now try to print.
Oct 13, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Fax reports no longer printing.
check the settings to ensure that ist is actually on. You may not have gone in there and changed them, but they will do it on their every now and again
May 22, 2009 | HP LaserJet 2840 All-In-One Printer
Touch screen on kyocera 5035 isnt working
Look for a stuck key on the operation panel. Usually is the least used key, a grain of salt will do it!
Jan 27, 2009 | Kyocera Copystar CS-5035 Copier
HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Jan 08, 2009 | HP Officejet 5510 All-In-One Thermal...
HELLO...WE HAVE AN HP PSC 950 PRINTER, COPIER, SCANNER , FAX AND IT PRINTS SUPER SLOW...THIS HAPPENED BEFORE AND I PUSHED A BUTTON TO CORRECT THE PROBLEM BUT IM NOT HAVING THE SAME LUCK THIS TIME...HELP!!
I would seem the quality is set to high instead of normal or draft (even faster). Right-click on the printer in the Printers and Faxes folder and select Properties. Under Printing Preferences you can set the default quality. When printing photos you can override this setting.
Dec 30, 2008 | HP PSC 950 All-In-One InkJet Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
