Question about Fisher and Paykel (IWL12)
My dishdrawer gives a F4 code. What does it mean?
    President:
  • 1,932 Answers
The F4 code means that the machine has sensed that the water temperature is not rising while the heating element is energized. There are tests to perform to determine if this condition is caused by a faulty heater plate or the machine's controller. The heater element relay can be energized in the diagnostic test mode, and if the heater does not come on, the heater plate can be tested with an ohm meter. Changing a heater plate is a fairly complex job and you would want to consult a service manual for the proper procedures.
From below website you can learn how to go to diagnostic mode and the reference chart
http://www.fisherpaykelparts.net/techsheets/603.pdf
Thank You
Posted on Sep 06, 2010
My kleenmaid ked600 condenser dryer is giving me a F4 error code. And not heating. Could it be the thermostat? Where can I locate the meaning of the error codes ?
In case of F0, F1, F2, F3, F4 failures,
contact your service technician without
hesitation.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/DR/KM_DR/KED600.pdf
and then I found this
"F4? Too much lint in the lint filter, front housing, or in the condenser Clean lint from lint filter and/or condenser I would just contact them.
http://www.kleenmaid-appliances.com.au/support/contact-us/
Mar 04, 2016 | Dryers
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
Jun 14, 2011 | KitchenAid Kitchen Ranges
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer Fisher & Paykel Dishdrawer no lights lcd
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel DD602 Dishdrawer: F4 code
an element fault (disconected or faulty controller)
Aug 01, 2008 | Dishwashers
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Washing Machines Logo
312 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
