No audio in captured video from analog tape audio is not muted audio scrubber is nor redlined.
Deleted it
Posted on May 14, 2008
How do i download my pictures from my handycam trv49e so that my tapes can be reused
Search Google and found this:
The Sony CCD-TRV49 camcorder doesn't have a digital output, so you have to capture and convert the analog composite video signal and audio signals. On the PC side you need an analog video capture board, a sound card to capture the audio and a video capture/editing software. You can also find on the market external USB devices that contains all these things.
The composite video is the yellow RCA connector that goes straight to your capture board.
The left audio is the white RCA connector and the right audio is the red RCA connector. These are mixed on a stereo jack plug that enters into soundcard input socket.
Source(s):http://www.allpinouts.org - Open Reference Archive for Connectors, Cables and Adapters Pinouts.
Jul 09, 2012 | Sony Handycam CCD-TRV49E Camcorder
Tip
How to convert analog video to digital format.
<p>Equipment needed <br /> <p> <br /> <p> <ol> <li>PC</li> <li>Analog Capture Card (you can find prices here)</li> <li>Sound card (some capture cards has their own audio input)</li> <li>Cables</li> <li>VHS Player/Camcorder</li> <li>Capture Software (Windows Movie Maker 2 can do this)</li></ol><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p>Steps to perform<br /> <p> <br /> <p> <ol> <li>Hook up your capture device to your computer</li> <li>Turn on your PC, install the drivers</li> <li>Hook up your analog player to your capture card with the cables</li> <li>Load your capture software</li> <li>Set the capture options (video and audio)</li> <li>Start the capture process</li> <li>Start the playback on your analog device</li> <li>Once the analog device has finished, press stop</li> <li>Stop the capture process</li> <li>Save the video</li></ol><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p>Remember, you capture card merely records the signals that comes from you analog device. If the footage is blurry and choppy, it's probably because of aged tapes or dirty video heads.<br />
on Nov 30, 2010 | Computers & Internet
How to conver analog vedio to digital
you need following Equipment
  1. PC
  2. Analog Capture Card (you can find prices here)
  3. Sound card (some capture cards has their own audio input)
  4. Cables
  5. VHS Player/Camcorder
  6. Capture Software (Windows Movie Maker 2 can do this)
and perform these Steps
  1. Hook up your capture device to your computer
  2. Turn on your PC, install the drivers
  3. Hook up your analog player to your capture card with the cables
  4. Load your capture software
  5. Set the capture options (video and audio)
  6. Start the capture process
  7. Start the playback on your analog device
  8. Once the analog device has finished, press stop
  9. Stop the capture process
  10. Save the video
Good luck, do rate the solution if helped
Nov 30, 2010 | Televison & Video
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
Captured Audio / Video Synchronization
Change the video format. What format are you making the new video?
May 08, 2009 | Computers & Internet
Cant capture sound with DVC 90 with vista
Make sure you check the recording source for audio and also the volume levels. Check the default audio input settings in Vista as well as the audio recording source in the recording program.
Jules
Dec 17, 2008 | Pinnacle Dazzle DVC 90 (210100371) Video...
Transferring VHS-C tapes from a Panasonic NV-RX14B to my PC
Search Ebay for peripherals to transfer tape to PC - they come with all leads and software.
Mar 28, 2017 | Panasonic NV-VZ14 VHS-C Analog Camcorder
Pass Thru, Analog Signal Converter How-To
I wonder if this is a MacroVision problem. Try this; take a VCR tape that you have recorded from the tv, try to record a commercial and then play this tape through your setup, I bet you it works. (Now take what I say next in the sense that it is given and that is as advice)When you are trying to push signal that you get from an analog source from the VCR by law that signal has to be encoded with macrovision to ensure that the signal can not be copied. Now the funny thing is you can transfer tapes which have not been encoded this is normal, what you need is a piece of equipment that removes Macrovision, here is a link that might help: http://www.regioncodefreedvd.com/copyeliminator.html also look up the company SIMA
Sep 07, 2007 | Sony GV-D200 Digital 8 TM VCR
How to use the MV6401 as an AD converter
There are more direct way of transferring VHS to digital format (MPG, AVI, etc. There are now cheap video capture devices like TV tuner, or a video capture card tha connects to USB 2.0 port. However if you still want to use this camera, this ?s what you need to do. 1. Connect the camera to the PC. Most MiniDV cams have an iterface called i-link, firewire or IEEE-1394. If your computer has no shuch interface, you have to install. 2. Record the analog video to the miniDV tape. 3.CApture the recorded tape to the PC. You need to video capture software to do this. You may need to convert the format to the format that you prefer. 4. Burn the vdeo to DVD, you will need a burner and video autthoring softare such as nero.
May 28, 2007 | Canon MV630i Mini DV Digital Camcorder
Transferring analog to DVD
I envisage two options for you: 1. Install a video capture card in your pc. Choose one that has ports that match your analog camcorder ports. Best option: Separate capturing using S-video + a separate audio connection. Common and simpler option: Campture "composite" video using one video + one audio jacks. You don't need a new camera to make DVDs from your analog tapes. 2. Buy a pass-through (must be this type, not all digital cameras have this function!) digital camera. Connection and flow: analog camera (or your analog VHS VCR)to digital camera (via RCA cables); digital camera to pc (preferably using Firewire)- all simultaneously. Here, the digital camera will perform the function of a capture card. You will certainly need a software to capture via capture card/pass-through digital camera to your pc hard disc. Your captured video on pc can be initially in AVI/ DV AVI(better options to edit) and then convert to MPEG2 (DVD) format, or directly in mpeg format (with poor editability). Frame size (capture resolutions) should be as big as possible. In any case you will need some basic knowledge on digital video, capturing, and editing. And all the nitty-gritty that you will need to know can be found somewhere like "Digital Video Primer" and "DVD Primer".
Sep 06, 2005 | Panasonic AG-185 Camcorder
22 people viewed this question
 Grubhead
Grubhead
