Question about HP Photosmart 8250 InkJet Printer
Hp 8250 printer
Does anyone know how to disassemble an 8250 printer
  • buck1107 Feb 26, 2009
    I got as far as trying to take the side off by sliding a small screwdriver into those 6 slots, but the part I can't figure out is how to free up the rear and front parts of the grey plastic wrap around trim.
    Are there additional holes to free up these sections, or does the section somehow slide to free them up?
Hi, Just took mine apart.
Lift up the lid, and squeeze the clips on the supports, and pull the lid toward you. Lid slides off. Then look along both sides ( edge ) of the printer, you will see about 3 elongated holes. Push a small flat screwdriver through these to release the clips which hold on the grey trim around the edges.
Next slide the rear part of the trim to the left, to remove it. At this point you should undo the 4 hex screws that hold on the top ( the lid is attached to it by ribbon cable ). There are two at the front, two at the back ( the ones at the back are in 'tunnels' ).
Ribbon cable will unclip from the right side of the printer ( the circuit board ) and you can set the lid / top aside. The actual side of the printer simply hinge out. Everything else is fairly straightforward.
Posted on Dec 25, 2008
Hp 8250 printing way to slow
hi x photomike,
check in the printers and devices for your printer hp 8250 and right click printer properties, printer prefereces and look for the quality/speed tab and press it to normal
Hope it helps bro!!!!
Jun 27, 2011 | HP Photosmart 8250 InkJet Printer
My hp 8250 constantly does not feed paper. It tells me to load paper when the tray is full. Often times I have to push the paper toward the rollers with my finger to get the paper to catch and have it...
There is a plastic switch that detects paper. You will probably have to disassemble it to get to it. It could be dusty and jammed or broken or stuck. If it's broken, you might check to see how much a local shop will repair it for. Often, it's just better to buy a new one. Good luck.
Mar 20, 2010 | HP - HP Photosmart 8250 printer
HP photosmart 8250 is printing different margins us a favor here..try a test page from printer selection panel. just to make sure it's not the may need to re install new printer drivers.
Nov 28, 2009 | HP Photosmart 8250 InkJet Printer
Expire dates on ink cartridge
I've found a site that has the photos for disassembly!
Nov 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink problem
I know this sounds silly but did you pull the blue tape off of the printer cartridge before you installed it? If you did, try removing it and installing it again. Maybe it was not aligned right. Also, there is a way in the HP printer software to instruct it that you installed a new cartridge - try that too.
Oct 03, 2008 | HP - HP Photosmart 8250 printer
HP Photosmart 8250 Support Menu?
I have the same issue with the printer but I do have a solution for you.
I do know how to reset the error codes.
Start by turning off the printer and unplugging the power cord.
Next, you need to hold the Instant Share and Photo Tray buttons simultaneously while plugging in the power cord. If done correctly you will see the LCD Screen turn green with the numbers '1 2 3 4 5'.
After that is done, you need to unplug the printer, and replug it.
I myself have not been able to resolve the issue as to why it is giving me the error code. Any help would be appreciated.
Jun 07, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 trouble
do you mean the installation CD of printer ? let me know
Apr 22, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
971 people viewed this question
Ben Johnson
